Wheel play
Old Apr 11, 2012 | 06:52 PM
TTschmitta's Avatar
TTschmitta
Default Wheel play
Lately iv been noticing alot of wheel play on my 93, any suggestions to help eliminate/minimize this? Would struts and sway bars help?
Old Apr 11, 2012 | 06:56 PM
k7q's Avatar
k7q
what kind of wheel play? need more infomation.
steering wheel play? rim/tire play?
Old Apr 11, 2012 | 07:17 PM
TTschmitta's Avatar
TTschmitta
Steering wheel, its not as responsive as id like
Old Apr 11, 2012 | 07:28 PM
k7q's Avatar
k7q
check rack & pinion bushings, inner and outer tie rods.
to check the tie rods. jack up the car and wiggle the rim/tire left and right to see if it has play.
Old Apr 16, 2012 | 03:01 PM
TTschmitta's Avatar
TTschmitta
The sc normally has a little wheel play as it is tho right?
Old Apr 16, 2012 | 03:11 PM
hovsc400's Avatar
hovsc400
steering rack bushings my friend when there bad your steering is terrible when mine were busted just to make a simple turn it was almost like doing a u-turn before the steering would respond
Old Apr 16, 2012 | 03:39 PM
TTschmitta's Avatar
TTschmitta
Its not HORRIBLE now after getying new tires (the old ones were gone!-which i didnt consider when posting this) but it still has a little play, more than id like..how is the steering normally? Doesnt it have a little play stock?
Old Apr 16, 2012 | 08:02 PM
TTschmitta's Avatar
TTschmitta
Anyone know where to find aftermarket so it will be a long time before i ever have to replace them again?
Old Apr 16, 2012 | 09:56 PM
hovsc400's Avatar
hovsc400
i got aluminum ones from drift motion i think it was about $50 bucks and my steering is nice and tight even with bad tires and a jacked up alignment which was the result from doing my lower control arm, but before the LCA job that steering bushing made a world of difference in the steering response and feel
Old Apr 17, 2012 | 10:35 PM
TTschmitta's Avatar
TTschmitta
I was searing drift motion and couldnt find the other day, what are they under? (i was in the sc/gs) and i have megan cintrol arms and coils already, when i set em stiff its better but i want to keep em soft and have goos response. Ill get the bushings and see if it helps, any other suggestions?
Old Apr 18, 2012 | 09:36 AM
TTschmitta's Avatar
TTschmitta
Nevermind i found em!
Oaklandsc3
May 21, 2014 07:54 PM
saiko2j
Feb 19, 2010 11:24 AM
sc400123
Dec 12, 2008 01:59 PM
Bryan858
Sep 14, 2004 06:48 AM
