Engine Miss
Old Mar 11, 2012 | 10:22 PM
mdmaniac's Avatar
mdmaniac
Unhappy Engine Miss
When I was jump-starting a buddy's GS300, a coolant hose blew off his heater-control and sprayed all over my SC. Not wanting to smell coolant for the next week, I rinsed my engine off with a garden hose (no high pressure) and all was good. I drove it to work that night and it was fine. I was coming home and it started to shudder, especially under acceleration. I thought, "OK, the clutch is finally going" and I babied it home. Then I noticed it was rough at idle but it seemed to smooth out when it was revved high with no load. No CEL at that point. I decided to drive it to work one more time and see if the problem would go away. It didn't, the CEL came on, instead, and indicated a P0300 (Random/Multiple misfire), P0303, P0305 & P0306 (3, 4 & 6 cylinder misfire).
Question 1: Could this be related to the washing the car got? I washed the engine a year and bit ago and it started missing on #1 cyl until I took everything apart and put it back together.
Question 2: What component is most likely causing this miss (whether it/they got wet or not)
I don't have a lot of time for fixing the poor girl right now as I'm working 12 / 7. I'm polling the forum simply because it'll cut down on my diagnostic time--hopefully giving me a solid starting place.
Thanks!!!
Old Mar 12, 2012 | 01:32 AM
mdmaniac's Avatar
mdmaniac
2JZ-GE btw.
Old Mar 12, 2012 | 04:51 PM
RudysSC's Avatar
RudysSC
I washed my engine bay, and about two days later it started doing the same. Had to replace the plugs on the cylinders where the misfire was. That fixed it for me, not sure if the circumstances are the same but it's worth a shot.
Old Mar 13, 2012 | 04:37 AM
mdmaniac's Avatar
mdmaniac
yeah, I'm pretty certain it needs plugs and wires. Like I said, last time it was just taken apart and put back together and that worked fine. Guess I might as well go ahead and give the girl a tune-up anyway. Now the weather's getting nice I can start riding the motorcycle
SteveMason
CT 200h Model (2011-2017)
12
Dec 27, 2025 05:55 PM
Bankswood
Jul 6, 2017 06:51 PM
Karwan
Nov 4, 2012 08:53 PM
TMaxxTim
May 4, 2006 09:43 PM
AJ
Apr 18, 2006 12:38 PM
