are they tunable?
Old Mar 8, 2012 | 09:22 PM
david12121's Avatar
david12121
Default are they tunable?
Hey guys
sorry if I'm posting this the wrong way or at the wrong place...first time posting
so I was looking for a SC400 and had a few questions
are they tunable? how much power can the engine and the transmission handle without any major upgrades? are they straight liners or handlers? reliable? gas guzzler? what 0-60's can they get?
any other info will be much appreciated
Thanks in advance
Old Mar 8, 2012 | 09:34 PM
BenStoked's Avatar
BenStoked
CL Folding 1,000,000
most of the questions you have depend on the year the sc400 you're looking at.
92-94 have the strongest motors internally, but they're also the weakest hp-wise.
95-96 have better power, weaker internals.
97+ best stock hp, weakest internals.
hp capability depends on year and the quality of maintenance performed in the past
(and by "weak internals", I mean compared to each other, not other cars, like DSM 1g's.)
not sure what you mean by "tunable" you mean upgradable? cheaply, no, but there's definitely support if you know where to look.
handling: let's put it this way: the mk4 supra was based on the same chassis as the soarer/SC.
I get between 15 and 25 mpg, depending on gas quality, and how bad my attitude is.
0-60 is kinda meh, getting about mid-7's in my car. It's also stock, not modified.
edit: from wikipedia
Tests conducted on the new engines showed an acceleration for the SC 400 for years 1992–1995 of 0–60 mph in 6.9 seconds, years 1996–1997 in 6.7 seconds, and years 1998-2000 in 6.3 seconds.
Old Mar 8, 2012 | 10:20 PM
david12121's Avatar
david12121
as for tunable I meant like can i just put a Garrett gtx3071 on it and get what...400whp without destroying the transmission in the first mile or two?
I currently have a Subaru SVX which is a pain in the A$$ when it comes to tuning...I want to get a car that is easy to tune and is good at everything...
Old Mar 8, 2012 | 10:30 PM
INTIMAZY's Avatar
INTIMAZY
A GTX3071 on a 4.0 liter V8 would practically spool at idle and choke the motor in the upper end.
400rwhp is not a lofty goal and you will have no issue hitting it reliably on a fairly stock drivetrain. Minor trans tweaks are recommended.
Old Mar 8, 2012 | 11:25 PM
g4ebguy90's Avatar
g4ebguy90
Quick question since you guys said 97's have most hp. I don't think my 97 has VVT, wouldn't it say on the motor somewhere like on a peice of plastic like on the IS300's???
Thought it was 98+ that have VVT. I got a sc400...
Old Mar 8, 2012 | 11:35 PM
david12121's Avatar
david12121
a gt4088 would work just fine tho...
so for 4whp you need something like 450 crank and i'm not very sure if a transmission made for a 250hp car can handle that much...has any of the people here done that?
also is there an easy manual swap, capable of 400whp, available for them?
Old Mar 8, 2012 | 11:57 PM
LunaVyohr's Avatar
LunaVyohr
1998 and up h ad VVT-i. 1997 did not, but they were uprated from 250 HP to 260.
You really should do some searching. These questions have been answered before. The A341E is a stout transmission - the same that's used in the TT MK4 Supras as far as I know. Add a trans-cooler, and it can see 400 HP.
As for manual swaps, there are multiple companies that make adapter kits for the W58 and R154 transmissions. Quantum Auto is the first that comes to mine. 'Easy' is in the eye of the beholder. A few select members on this forum have used the V160 transmission, but this requires a lot of custom work.
You should go to Lextreme and do some digging. Most, if not all of your questions will be answered.
Old Mar 9, 2012 | 12:16 PM
david12121's Avatar
david12121
well based on my experience people who have done it before are the best source
thanks though...helpful lexus-ers
good luck
Victor22P
Nov 5, 2017 05:13 AM
$l1ckr4y
Dec 28, 2013 12:50 PM
LT1Z28
Jan 12, 2007 06:00 PM
BennySC400
May 1, 2006 09:36 AM
ERicincal
Apr 11, 2002 12:01 PM
