Engine Mount
Old Oct 23, 2002 | 09:54 AM
VSsc400's Avatar
VSsc400
Default Engine Mount
I have a 92 SC400. When I put the car from Drive to Park and from Park to Reverse and from Reverse to Driver or vice versa I feel the car jerking. I think is the engine mounts. Is this enough to diagnose? I thin its time that I replace them. Does anyone make a higher quality engine mounts than Lexus? Any info on this?
Old Oct 23, 2002 | 01:56 PM
Lex Luthor's Avatar
Lex Luthor
They're know to weaken on these cars, i'm replacing both motor mounts and trans mounts as we speak.....
Old Oct 23, 2002 | 04:00 PM
VSsc400's Avatar
VSsc400
is there a aftermarket mounts or are you replacing them with stock?
Old Oct 23, 2002 | 05:53 PM
Lex Luthor's Avatar
Lex Luthor
TRD makes a set of mounts for the 2JZ, but not for the 1UZ as far as i'm aware, so no, two stock Lexus motor mounts and two stock Lexus trans mounts.
Old Oct 23, 2002 | 08:00 PM
Skulinex's Avatar
Skulinex
you can stiffen theh tranny ones up with polyurethane...before installing them, you can fill them in with roofing poly. and let them dry over 12hrs or so and then you can install them. You gotta make sure when you apply the pol. you don't leave any empty space for big air pockets to form..
Ztram
Jul 14, 2016 11:34 AM
Gskis
GS - 1st Gen (1993-1997)
Mar 21, 2010 12:26 PM
most
Sep 9, 2008 08:38 PM
CDY
Mar 30, 2008 09:42 PM
nicola
Nov 7, 2005 07:22 AM
