wiring questions...
Old Feb 19, 2012 | 09:30 AM
illeagle's Avatar
illeagle
Default wiring questions...
i just bought this sc300 and the blinkers and hazards are not working. the previous owners said it was broken into and the radio was stolen and after that it stopped working. i have seen people asking if the center console was disturbed in other posts. everything looks good but why is that important? my main problem is im trying to find a wiring schematic so i can arrange all the wires accordingly and maybe find the correct wires to poke at. the pictures show some bizarre wiring. one picture shows just a bundle of wires that are taped off using masking tape. they have pin acceptors like they go into a plug but there is nothing in sight. another pic shows a random grey plug i found laying below everything that wasnt plugged into anything but i cant find where it goes either. another pic shows a stripped wire that goes from 2 brown wires and was wrapped around the black and white wires going to the hazard switch. it was held on with loose shrink wrap. the other pic shows how the radio was cut and removed. any info is appreciated even if i get this fixed in bits and pieces i just want to get it fixed. the main thing i was is a wiring diagram/schematic. thanks
scotty
Attached Thumbnails wiring questions...-img_20120219_104323.jpg   wiring questions...-img_20120219_104342.jpg   wiring questions...-img_20120219_104449.jpg   wiring questions...-img_20120219_104546.jpg   wiring questions...-img_20120219_104637.jpg
Old Feb 19, 2012 | 09:55 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Pic 1 - Top plug (only one left) is the hazard plug and long as that is plugged in it SHOULD work. The rest of the plug wires are for the volume and shouldn't affect the other functions. Make sure the wires from that plug go back properly and are not cut.
Old Feb 19, 2012 | 09:59 AM
illeagle's Avatar
illeagle
thanks OLT... i got the hazard plug plugged in with everything else off so im trying to follow the wires to see if anything went wrong. its just so hard to see where all the wires go since everything was so dis-organized.
Old Feb 19, 2012 | 10:19 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
give me a few................
Old Feb 19, 2012 | 10:36 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Hmm ok that plug is the volume plug, oddly enough so the hazard plug is missing and that's why nothing works.
This entire harness piece can be gotten as a one piece deal as you can see, from any parts car.
Attached Thumbnails wiring questions...-img_1821.jpg   wiring questions...-img_1823.jpg   wiring questions...-img_1824.jpg   wiring questions...-img_1825.jpg
Old Feb 19, 2012 | 10:39 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Also, these wires are nothing they are just the aftermarket adapter plug for the radio that doesn't belong in the car in the first place, you can just unplug this and set this plug aside for a rainy day incase you go back with an aftermarket deck. That's power for the radio.
Old Feb 19, 2012 | 10:42 AM
illeagle's Avatar
illeagle
holy cow then what was plugged into the hazard switch. blah i hate dumb people.
Old Feb 19, 2012 | 10:52 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
see, here's volume and temp
Old Feb 19, 2012 | 10:56 AM
illeagle's Avatar
illeagle
ok i defenitely get it now. thanks a ton i guess he had something else plugged into the hazard switch. now its time to source a plug from a junk yard i suppose. and i just downloaded a complete 4000 page manual from a file share site i hope it helps. thanks again.
Old Feb 19, 2012 | 11:01 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
and just because I can't leave well enough alone......... here's the hazard and the pinouts incase you wanna use flat pin connectors from radio shack to try and DIY the pinouts.
Schematics my ***............
Attached Thumbnails wiring questions...-img_1829.jpg   wiring questions...-img_1831.jpg   wiring questions...-img_1832.jpg   wiring questions...-img_1834.jpg
Old Feb 19, 2012 | 11:06 AM
k7q's Avatar
k7q
OLT is king
Old Feb 19, 2012 | 11:56 AM
illeagle's Avatar
illeagle
ok got the wires set into the switch and sure enough my blinkers work now. this is perfect. thanks a ton. yes OLT is king.
Old Feb 19, 2012 | 12:18 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
WOOT, working blinkers are a plus. Get's old using the finger.
jmac2k11
GS - 1st Gen (1993-1997)
Oct 14, 2012 09:12 PM
2slow
Feb 27, 2007 07:32 AM
stokdd
Aug 29, 2006 07:50 AM
Tri5spd
IS - 1st Gen (2001-2005)
Sep 3, 2002 01:26 AM
