got angle
Old Feb 10, 2012 | 11:27 AM
sclee00's Avatar
sclee00
Default got angle
what are some good outer tie rod for more angle
Old Feb 10, 2012 | 12:30 PM
Toyboxx's Avatar
Toyboxx
As far as I know, there aren't any aftermarket tie rod ends available besides Megan. What most people do is get their knuckles chopped and rewelded to add angle. I believe Battle Version and PSM does it.
Old Feb 10, 2012 | 01:17 PM
ho0dlumka's Avatar
ho0dlumka
Pbm has really good products
Old Feb 10, 2012 | 01:22 PM
abounly's Avatar
abounly
https://www.clublexus.com/forums/dri...s-testing.html
Old Feb 10, 2012 | 03:05 PM
sclee00's Avatar
sclee00
i have the knuckes cut already
Old Feb 10, 2012 | 05:09 PM
poorsupra's Avatar
poorsupra
i believe this has already been addressed in the other steering angle thread. a tie rod end itself wont give you more angle, you already got your knuckles done, tie rod ends with rod ends are more durable and with a spacer can provide a better angle for bump steer due to a lowered car. please revisit that thread. lots of info there, megan, batter version, or just make your own.
Old Feb 10, 2012 | 05:49 PM
sclee00's Avatar
sclee00
im just looking for the tie rod ends such as megan, battle version. im looking for personal experence with any of these products
Old Feb 10, 2012 | 08:56 PM
ArodDaLob's Avatar
ArodDaLob
Since when did bver have tie rod ends? And what is this nonsense about outer tie rod ends giving more angle?
Inner tie rods can increase angle, but wont always until you add a spacer. Tie rods like uras already have a spacer integrated onto the threading, so thatll allow for a tiny bit more angle. Im currently running just a spacer with stock inner and outer tie rods.
Old Feb 11, 2012 | 05:58 AM
afro88's Avatar
afro88
From what most people who modify knuckles have said, adding tie rod spacers to a knuckle setup is a waste of time. Seems like this is especially true in SC's. Max angle with PSM knuckles is around 65 degress of angle. Most people will not be able to achieve that due to the amount of fender well/swaybar clearance needed. According to Dan at PSM and Alex at Battle Version stock tie rods are more than strong enough. Only reason to change them is for bumpsteer adjustment.
I've personally been looking at the Yanack ones simply because of how much bumpsteer adjustment they give you and how low I plan on setting my car.
Old Feb 11, 2012 | 02:40 PM
sclee00's Avatar
sclee00
Boom answered, thank you
solara2xb
Suspension and Brakes
May 22, 2017 03:48 PM
MumRah
Jun 6, 2012 06:15 PM
Turb0wned
Apr 8, 2010 02:13 PM
ronricorum
Oct 31, 2009 02:29 PM
