Gte tps help!
Old Feb 8, 2012 | 07:06 PM
broda805's Avatar
broda805
Default Gte tps help!
hey i just retrofitted a jdm gte upper mani to my ge motor and im having trouble with the gte TPS. the old tps from the stock GE wont work ( it spins the other way) when the GE tps is plugged in it shows 0 volts and will go upto 4v or so when you turn it by hand as it should ( viewed via AEM EMS)
when i plug in the GTE TPS it just sits there at a full 5v.... do i need to switch some wires around or something? i looked over the wiring pinouts for gte ecu and it looks the same as the GE but i cant figure this out
what im suspecting is that ... maybe the wires need to be reversed..... since it spins in the opposite direction? haha
Old Feb 9, 2012 | 11:53 AM
TLDriver's Avatar
TLDriver
I believe I have read about this on supraforums before... I will look around
Old Feb 9, 2012 | 11:59 AM
TLDriver's Avatar
TLDriver
http://www.yotatech.com/f161/finishi...z-swap-215577/
post #2 and #3 good luck
Old Feb 9, 2012 | 07:33 PM
broda805's Avatar
broda805
thanks man, i think i got it, either jdm thing or a gte thing the wires are just in reverse order and for some reason my "blue yellow " wire is green? blu+yel=green? haha
weeters
Jul 12, 2016 12:13 PM
chek128
Apr 25, 2014 04:39 PM
rcchris7
Nov 27, 2012 02:59 PM
zbigniew38
Aug 23, 2011 06:46 PM
broda805
Jun 14, 2011 04:48 AM
