Reading Codes
Old Jan 14, 2012 | 12:08 PM
hoosier58's Avatar
hoosier58
Default Reading Codes
I haven't seen anything here about reading the codes on SCs. My Ford van OBD I codes can be read with the check engine light by putting a jumper in the diagnostic plug. I have a cheap actron code reader, but find it easier to sit in the seat and do it with the check engine.
I'm guessing my 94 SC3 will be OBD I also. Do codes have to be pulled with a reader, or is it possible to use a jumper and the check engine light?
Old Jan 14, 2012 | 01:20 PM
LuNaSc3's Avatar
LuNaSc3
My 93 is OBD1. Gotta jump different terminals for different things. Different things will blink depending on what you're checking/jumping, gotta count blinks. Service manual would be helpful
Old Jan 14, 2012 | 01:23 PM
LuNaSc3's Avatar
LuNaSc3
The OBD1's can usually be found under the hood or under the steering wheel to the left, right underneath where you pop your hood/trunk
MnM24
RX - 1st Gen (1999-2003)
Sep 2, 2012 05:05 PM
GOLDSc300
Maintenance
Apr 15, 2007 07:32 AM
healerhand
Jun 13, 2002 04:30 PM
