Steering wheel tilt help ASAP PLEASE!
Old Nov 14, 2011 | 09:58 AM
TTschmitta's Avatar
TTschmitta
Default Steering wheel tilt help ASAP PLEASE!
I own a 93 Sc300 and my steering wheel tilt wont go up or down. I just came from the lexus dealership and they told me its a $2800 reapair!!! How is this possible? Has anyone had to deal with this problem before and what is my best option? Should i start looking on craigslist for a whole new steering assembly to replace mine or is there another route to take? Any and all help is very much appreciated..... this is truly ruining my day!
Old Nov 14, 2011 | 11:30 AM
SourLex's Avatar
SourLex
search the forums, there was a member that fixed his tilt problem with a 2 dollar gear from home depot or something like that. he also did a diy for it. sorry for not findin the thread for you....im lazy.
Old Nov 14, 2011 | 11:35 AM
rbigshow04's Avatar
rbigshow04
Here's the DIY https://www.clublexus.com/forums/sc-...ng-repair.html If you need any help let me know
Old Nov 14, 2011 | 11:44 AM
sj408's Avatar
sj408
2800 lmfao they just didnt wanna touch your car. stealerships are insane. They told me they couldnt diagnose an engine problem because my suspension was too heavily modified and they would have to return it to stock LMFAO
Old Nov 14, 2011 | 07:50 PM
TTschmitta's Avatar
TTschmitta
I knew they were overpriced and **** but last time i went they said $180-350 repair so i was shocked. When i searched it came up empty which i thought was weird but when i just got on i saw the thread of the guy with the washers and pictures so hopefully that will work, tomarrow i think will be judement day, wish me luck. And thankyou for posting the link!
Old Nov 14, 2011 | 08:27 PM
SEXC's Avatar
SEXC
I have the same problem with mine but I think it's the ecu that went bad. I can move the steering wheel up and down by pressing the button but it won't do it on it's own when inserting or removing the key.
Old Nov 14, 2011 | 08:34 PM
jjffyy's Avatar
jjffyy
I had the same problem and fixed it with the method in the DIY. Worked like a charm
Old Nov 14, 2011 | 08:36 PM
unknown159's Avatar
unknown159
mine goes up and down but doesnt come out when i try to extend it....
Old Nov 17, 2011 | 03:15 PM
TTschmitta's Avatar
TTschmitta
It is all fixed and working!
Old Nov 18, 2011 | 06:41 PM
rbigshow04's Avatar
rbigshow04
Good to hear
Old Nov 18, 2011 | 08:04 PM
imDementeD's Avatar
imDementeD
@ unknown159 mine just started doing this as well......TTschmitta...can you explain further, did yours not go in/out and up/down and that fix, fixed everything ...or did only up/down not work and now it does?...thanks would like to fix my in/out as im short (5ft8) and would prefer my wheel be closer then the furthest setting away from me..Thanks
Old Nov 19, 2011 | 02:38 PM
Reesetrict's Avatar
Reesetrict
Same problem here, was an easy fix. If only there was a solution this easy for my seat not moving back and forth... Planning on ripping out the boat anchors and going lightweight.
Old Nov 21, 2011 | 07:47 AM
TTschmitta's Avatar
TTschmitta
from me..Thanks
Mine just wouldnt go
Up an down...but from my understanding the method
mentioned above works either
way. If not then it could be the
ECU i was told on Soarerworld.
Either way Just DONT GO TO
LEXUS! Lol. But if your motor is making noises when u try to move it, you shouldnt need a new one like i was told at Lexus.
phongminh
Mar 20, 2008 06:31 PM
sc300L
Nov 18, 2006 03:28 PM
99LS400
Maintenance
May 1, 2004 12:00 AM
