Powersteering issues
Old Oct 18, 2011 | 06:49 AM
Biggu's Avatar
Biggu
Default Powersteering issues
So as some of you guys know i got into a fight with a wall a few weeks back on the track. Im having some issues with my power steering now and im not sure if its the rack or the the pump.
when I hit, i hit on the driver side wheel and bent the lower control arm. When I turn the wheel now, its very tough. with the car running and I open the power steering reservoir and look in the fluid isnt moving at all, normally it should be swirling in the reservoir.
Do you think its the rack or the pump? the belt is running the pully. I was going to try and un do the line and loop it back to the res to see if it starts moving again. I may just buy a new rack to be safe anyways.
ideas or suggestions?
Old Oct 18, 2011 | 07:09 AM
Nova's Avatar
Nova
There is a good chance it's the rack or the line could be kinked from the meeting with the wall can u get under the car and check the lines going into the rack
Old Oct 18, 2011 | 07:25 AM
Biggu's Avatar
Biggu
The lines going from the pump and the line from the res are fine. The metal lines seem fine as well. I was going to try and un hook them and see if there is fluid pumping at all.
Old Oct 20, 2011 | 03:44 PM
Nova's Avatar
Nova
did u try unhooking the lines to see if it is pumping? i think your going to find some will still come out my bet is some internal damage to rack happened to one of my other cars once when i slide into a curb.
Old Oct 21, 2011 | 06:39 AM
Biggu's Avatar
Biggu
replaced the rack yesterday and all is well now.
Old Oct 21, 2011 | 07:43 AM
Luv2xl's Avatar
Luv2xl
dealer or aftermarket? If aftermarket who did you end up going with?
Old Oct 21, 2011 | 10:17 AM
Biggu's Avatar
Biggu
I bought it from oreilly auto since my cost was just shy of $200 for a reman with new electronics.
Old Oct 21, 2011 | 10:19 AM
Luv2xl's Avatar
Luv2xl
not bad.. lifetime warranty?
Old Oct 21, 2011 | 03:28 PM
Nova's Avatar
Nova
glad to hear it worked out for u!
Parson
Nov 23, 2018 09:22 PM
Grendal666
Aug 1, 2016 06:51 PM
SCereal
May 1, 2014 02:22 PM
jdub20tx
Aug 8, 2012 06:29 PM
lexrod6
Jan 16, 2012 03:26 PM
