power window problem
Old Jul 25, 2012 | 08:04 PM
BlaineyB's Avatar
BlaineyB
update, bought a master window switch, but still no luck. is it possible that even if you replace the master window switch, and it still doesn't work, does that mean that the passenger switch might be the problem, does the passenger side window switch have an effect of the master window switch not working?
Old Jul 25, 2012 | 08:05 PM
BlaineyB's Avatar
BlaineyB
bumppppppp.
Old Jul 25, 2012 | 08:33 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Do what 93SC300. told you to try.
Find wiring diagram then bypass it, if no go, then the regulator is weak and need's to be replaced.
Old Jul 25, 2012 | 08:46 PM
BlaineyB's Avatar
BlaineyB
i would, if i knew how.
Old Jul 25, 2012 | 09:03 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
To bypass the switch? Or search on the internet?
To bypass the switches, simply remove the switch, and touch the two wires together.
The wiring diagram for the power windows will be in the shop manual if you have one.
Cheers
Old Jul 25, 2012 | 09:07 PM
BlaineyB's Avatar
BlaineyB
to bypass the switch.
Old Jul 26, 2012 | 07:42 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Let us know what the problem was.
Good luck
Old Jul 26, 2012 | 09:08 AM
megamax's Avatar
megamax
My window still dosent wrk.
Old Jul 26, 2012 | 04:36 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
You could test the regulator by putting by removing it and passing 12V current through it. ( I know it's not to easy, but hey, things could be WAY worse!)
Remove the door panel and visually watch what happens when you press the switch to close the window. If it jerks, it's not totally gone. If nothing, it is most likely an electrical harness or connector. Search through the system by locating a diagram, (ANY CL?) and finding loose connectors and such.
Cheers!
Old Jul 26, 2012 | 06:57 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
It's the wiring in the drivers door. I had to re-wire Cal's door for the exact same issue on his SC. If you look in the harness where it goes through the door you'll see the spot the wire is broken at, it'll have some damage. It's usually inside the actual flex loom of the door hinge. There are 6 wires coming from the switch that are responsible for this action and one of them will pretty much be broken in half.
Old Jul 26, 2012 | 08:13 PM
BlaineyB's Avatar
BlaineyB
thanks for the input guys. I'm going to take a closer look this weekend. i will keep you guys updated.
Old Jul 26, 2012 | 08:52 PM
megamax's Avatar
megamax
i will hopefully look tomorrow. it's been too hot to be alive lately.
Old Jul 29, 2012 | 02:56 PM
BlaineyB's Avatar
BlaineyB
did you find out what it was megamax?
Old Aug 29, 2012 | 05:25 PM
megamax's Avatar
megamax
bump
bump
bump!!!
come on club lexus!!! let's find a solution here. i got my driverside door panel off. my ds door window has come down and will not go back up. dosen't sound like the motor is moving when iam pushing it to go up.
does anyone know which wires i cross on a 94 sc400??
Old Aug 29, 2012 | 05:40 PM
megamax's Avatar
megamax
come on c.l. help me out!!
