More starter problems
Old Aug 13, 2011 | 01:31 PM
619Rider's Avatar
619Rider
if you have or anyone else has a non working starter for 2jz, I will buy it
Old Aug 14, 2011 | 07:36 PM
OneJay's Avatar
OneJay
Thanks, you're super helpful.
Another update: Car started when I ran a wire to the starter plug, and touched it to the + terminal, so the starter works fine. I'm thinking it has something to do with wiring, or a bad ignition terminal. Or if anyone has any other ideas, let's hear them!
Thanks for all the help so far everyone!
Old Aug 15, 2011 | 02:47 AM
D3AN's Avatar
D3AN
Have you tried jumpering pins 3 and 5 on the starter relay to bypass it? Did you check the ignition/starter fuse in the kick panel?
If you are not hearing a click from the starter at all, it sounds like a circuit problem.
Old Aug 15, 2011 | 12:01 PM
OneJay's Avatar
OneJay
Which fuse is the ignition fuse? I'm using this diagram and not seeing it on there. http://soarercentral.com/sc-forum/me...82/100636.html
And I haven't tried jumping the pins. Where is the starter relay? In the main fuse box?
Old Aug 15, 2011 | 03:03 PM
D3AN's Avatar
D3AN
Old Aug 15, 2011 | 03:05 PM
D3AN's Avatar
D3AN
ya the starter relay is in the main fuse box in the engine compartment, best to check all fuses first before jumpering
Old Aug 15, 2011 | 03:24 PM
D3AN's Avatar
D3AN
you could even check the relay first, there should be continuity between pins 1 and 2, and no continuity between 3 and 5. If you apply battery voltage across 1 and 2, you should hear a click and get continuity between 3 and 5
MOAWINGS
Aug 26, 2020 04:19 PM
Alphaman19
May 21, 2014 08:09 AM
SuicidnS13
Nov 2, 2010 08:51 AM
sockfocks
Maintenance
Jun 17, 2006 07:06 AM
RA40
Maintenance
Mar 3, 2005 01:09 PM
