sc300 kick panel wire clip help
all i need is someone to tell me if the clip in the pic is plugged in on their stock sc300.....i cant find a clip to plug in and my car wont start
the pic is sideways, the left being the top, the right being the bottom....this is the drivers side kick panel
thanks in advance.....
When I re-ran my tire well harness I plugged a clip in but didn't secure it in all the way and tried to start my car and it wouldn't start. I got power to everything, it all looked normal then no crank. I securely got the plug in with the little latch on the bottom and then tried and it fired right up. So yes if a plug is not plugged in down there your car will not start. From the pic (can't tell to good) it might be that same plug.
Should be a big white plug with a black or yellow lever type on the bottom of it, iirc.
well, i've been doing alot of work to my sc300 and i cant find the plug circled in the pic above(first post)...i've read somewhere that the plug comes from the cowl but i've looked and i can't seem to find it, but some(not all) of the prongs have power with the key on....i'm getting no spark, and no fuel unless i hard wire the fuel pump....although i do have power at the ecu, both ecu grounds are good-the motor is grounded as well
gemineye
Feb 13, 2024 10:30 PM
nivek5sfe
Aug 6, 2010 11:29 AM
