1JZ Knock Sensor Extension
Old Jun 30, 2011 | 09:55 AM
88supramki's Avatar
88supramki
Default 1JZ Knock Sensor Extension
So as the time draws closer to doing my 1J swap, I have been doing more research than I probably did my entire 4 years in college. I have read many occasions of people extending the knock sensors with USB cables because they are shielded. I recently had a thought...what about using a decent quality Video RCA cable. It's a single channel shielded wire.
I used to work at a car audio shop and still have connections to get materials cheap. I was wondering what some of the experts think about this idea.
And before it's mentioned, yes I have looked into the Autosport wiring patch harness and that is not totally ruled out.
Old Jun 30, 2011 | 11:15 AM
cartmill's Avatar
cartmill
it's really not that big of a deal man
go for it
Old Jun 30, 2011 | 11:20 AM
88supramki's Avatar
88supramki
Hahaha, I did a lot more reading at SF and found that a lot of people used USB cables with no issues. I'll figure out more when the time comes. Looking forward to getting my motor in less than a month!
Old Jun 30, 2011 | 01:03 PM
account2x's Avatar
account2x
If the gauge is the same that would be fine.
I use the knock sensor wiring from your GE harness when I extend the harness.
USB wiring is a terrible idea because of how thin the wire is.
Do no forget the cam and crank sensor wire is shielding and needs to be extended using shielded wiring.
Old Jun 30, 2011 | 01:10 PM
88supramki's Avatar
88supramki
So the following wires are shielded: cam sensor, crank sensor, knock sensor? Is that a total of 6 wires? This is good to know. I want to make sure that I've got all of my information ready prior to diving into this. I thought about pulling the knock sensors from the GE harness as well. How tough and time consuming is that?
the issue that I have with that is that my car is my daily driver and I want as little downtime as possible.
Old Jun 30, 2011 | 01:18 PM
account2x's Avatar
account2x
non vvti has 2 cam sensors, vvti only have 1.
cam and crank sensors each have two wires inside them.
There is a store in Costa Mesa called MarVac that I buy my shielded wire from.
I have a bunch of extra knock sensor wire that I could give you for free if you were in the area.
Old Jun 30, 2011 | 01:28 PM
88supramki's Avatar
88supramki
I can make a trip down there
msekanha
Aug 7, 2012 02:12 PM
joewitafro
May 26, 2008 08:04 AM
JJG2005
Jul 16, 2005 04:35 AM
