Maintenence before I move
Old Jun 28, 2011 | 10:15 AM
durtysc300's Avatar
durtysc300
Default Maintenence before I move
I'm making a big move (Nebraska to Arizona..like 1200 miles, 19ish hours) in late September and while I trust my car to make it down there, I'd feel better with a tune-up. My question is, what sort of things should I do before I move? It runs great 95 percent of the time..some days though it will idle low or stall but its pretty rare. Sometimes it gets reaaaaaaaall hot though. I deliver for Jimmy Johns and it was an 90 degree day and I left my car on for like 20 minutes and it was overheating.
It's a 1995 SC300 automatic with 137k miles on it.
The previous owner was Markel BMW Mercedes Lexus and I think Porsche's owner's wife so it was taken care of..but she sold it to the dealer I bought it from with 102k miles on it and I've put on 35k. This is what I think I should probably do.
Oil Change (obviously)
Coolant flush
Spark plugs
clean the MAF
Struts and Springs
Rotors and Pads
But I also have a bunch of oil on the undercarriage of my car too, but I have no clue where its coming from.
Old Jun 28, 2011 | 10:34 AM
Tabaka's Avatar
Tabaka
I have the same issues my friend. From what I gathered from my thread...run a code scanner even if you don't have a CEL light, but yes, you should definitely do a tune up. You probably have a leak from any numerous places...valve covers, o'ring, RMS, etc.
Old Jun 28, 2011 | 10:54 AM
BigBang's Avatar
BigBang
change all your fluids. check your tires make sure you got a spare.
Old Jun 29, 2011 | 04:30 AM
Tament's Avatar
Tament
Tune up and get AAA, it will save you alot....
Old Jun 29, 2011 | 10:30 PM
MR_Clean's Avatar
MR_Clean
Do everything you mentioned IMO. If your car is overheating source the problem. Replace your thermostat if you have not done that yet, it can save you a big headache in the future. Sometimes you can get obstructions in your cooling system and it will cause your car to have intermittent heating issues. You can do a full flush and hope that your problem is solved or do a check on the whole system. Make sure your water pump is good, try wiggling the pulley to see if there is any play. Are you running the stock shroud?
Definitely check your tire pressure and have a spare handy, that can save you a lot of time/money. Replace your wires, plugs, distributor cap and rotor...make sure your plugs are gapped correctly.
There are a millions things you 'can' do but probably are not necessary. I would start with the essential maintenance and go from there, though.
Old Jun 29, 2011 | 10:46 PM
iridebmx's Avatar
iridebmx
i had oil on my undercarraige too and my sc400 just recently blew up because i guess the leak got worse without me knowing and i didnt even go 3,000miles before the last oil change
Old Jun 30, 2011 | 07:33 AM
ThomasGS4's Avatar
ThomasGS4
I had oil on my undercarriage too. Turns out it was a leaky oil pan, and it ultimately killed my alternator.
CRowe14
Sep 29, 2016 01:52 PM
Fabrizio1
Jan 4, 2015 02:44 PM
KJFenton
Oct 6, 2014 05:35 AM
Loyaljon
Oct 19, 2012 12:03 PM
thatWESguy
Lexus Vehicles Classifieds
20
Jul 12, 2011 05:20 PM
