aristo wiring experts needed
These are the two connectors that are connected to the rack pinion. The wires were not connected to anything. There are a total of 4 wires between the two connectors. Grey connector has light green w/ black stripe, and light green w/ red stripe. The Black connector has light green w/ red stripe and brown w/ grey dot.
EB1 Pin 7 has a wire that goes to pin 1 on the AC clutch. Then a wire branches off of that wire and connects to pin 1 another AC related connector called II1.
Grey connector:
The LG-R goes to IJ2 pin 16
The LG-B goes to IJ2 pin 6
Black connector:
AFAIK is not used on an Aristo swap.
You can try:
LG-R wire to the small ecu plug on pin 35
Brown wire to IK1 pin 1 or directly to one of the engine ground pigtails on the intake manifold.
Pics of IJ2 and IK1 attached for reference.
Grey connector:
Black connector:
You can try:
EB1 pin 4 (Black/Yellow)goes from 30 amp EFI fuse to small ecu connector, pin 33 BATT.
EB1 pin 8 (Black/Orange)goes from EFI main relay to small ecu connector pin 24 M-RELAY.
EB1 pin 6 (Black/Red) goes from ABS relay pin 5 to data link check connector pin 23
EB1 pin 1 (Lavender) goes from ac clutch relay pin 3 to ac clutch pin 4
EB1 pin 2 (White) goes from ac clutch relay to small ecu connector pin 23 ACMG
EB1 pin 7 (Brown) goes from ac temp sensor to Il1 pin 1 and ac clutch pin 1
EB1 Pin 3 (Black) goes from starter relay pin 1 to various places depending on if the car is auto or manual. Let me know if you need more info on that one...
I think that is it.
I think that is it.
What is pin 6 suppose to be connected too.
Grey connector:
Black connector:
You can try:
Grey connector:
Black connector:
You can try:
On Eb1 connector, pin 3 is the blk wire, pin 5 is the blue w/ red stripe. The blue w/ red stripe is not going through the harness at all. However, the the blk wire is connected to blue w/ red stripe in the harness. Not at the connector at all. When I traced the wire, it is connected to pin number 6 (blk w/ white stripe) on the grey connector (14 pins).
They tied EB1 pin 3 to IJ1 pin 6 to bypass the Neutral start switch. That is fine to leave like it is so the car will start. So they just used a blue/red wire to tie between the two, or does the splice effectively tie EB1 pins 3 and 5 together?
They used a blue w/red wire to between the two wires. So, I gues I should leave this the way that it is. What the actual blue with red wire? Do I need to hook it up?
There are a few wires that are left over. The are some that I know should be there, and they aren't. These are mainly on body plugs. So, I hope that you guys are still on board.
First, on the Grey connector (14pin), The two Org/ w blk stripe wires are not connected to anything. Should connect these to other Org w/ blk wires?
On the same connector, Pin 2 (red w/blue stripe) isn't connected. Pin 14 (white w/blk stripe), isnt connected. I know that pin 2 is supposed to be connected, I dont know where.
The Orange connector (23 Pins), Pin 6 (red wire) and pin 7 (blue w/red wire) are not connected. In the notes that I have, they show both connected to light blue wires. I did find two wires, but I wasnt able to trace them.
On the smller grey connector (17 pins), pin 13 (blk w/yellow) isnt connected. Where should I connect this wire? To another blk w/yellow wire?
On the White connector (12 pins), pin 2 (Red w/ blue stripe) is connected to pin 7 (blk w/yellow). How should these be correctly hooked up?
Last, on the white connector (25 pins), there are only 2 wires pin 9 and 24. are there suppose to be any other wires on this connector? My notes show pin 2 and 25 should be connected.
