Transmission
Old Sep 12, 2002 | 12:41 PM
KILLERLEXUS's Avatar
KILLERLEXUS
Default Transmission
did any one change a transmission for a sc400? if so how much? or how much to rebuild...my car does not want to move, feels like gears or torque converter not engaging,,car moves but does not really want to, the engine just revs really high with little movement.....help
Old Sep 12, 2002 | 03:04 PM
KILLERLEXUS
i just went to check the tranny fluids and its ok..i thought it might be low..guess not...when i start the car it will go in to gear but after a minute it doesnt seem to drive,, more like in neutral,car does not move and it rolls back and forth, ..not good...the car seems like its stuck in neutral, but when i restart the car it will let me put it in gaer and move a few more feet...arhhhhHHh...but no more then that,, the car just revvvvvs......helppppppp
Old Sep 13, 2002 | 08:57 PM
London Bill's Avatar
London Bill
Sounds like the box has gone, needs pulling and a "PRO" rebuild if you can get one, I ended up buying a s/hand box from a wreck after suffering 3or4 crappy rebuilds.
Old Sep 14, 2002 | 02:58 AM
KILLERLEXUS
box?.....how much did it cost?......what does that part do?. is it clutchbelt....may be shift linkage?
Old Sep 14, 2002 | 08:37 AM
London Bill
Box - Autobox
S/hand - £400GBP
Rebuild - £1500GBP
New - £4000
Labour for fitting £250GBP
I doubt it is your linkage, does it lock-up in "P" and freewheel in "N"?
Old Sep 16, 2002 | 10:29 PM
KILLERLEXUS
yes it does lock up in p..and rolls in all the other gears ,,the car moves if i shut it off and restart it ,,but it moves very little and starts to loose grip on torgue converter....
Old Sep 17, 2002 | 12:44 AM
strongsail's Avatar
strongsail
did you check the fluid level with the engine running?
Old Sep 17, 2002 | 02:20 AM
KILLERLEXUS
yepz, checked fluids....like i said if i start it up it will go in to drive or reverse and move a few feet before the tranny starts to slip ( revs high with very little forward movement) probably it is the torque converter...has any one else had problems?
Old Sep 17, 2002 | 06:31 AM
London Bill
You will have to take it to a shop, it is most probably the clutch bands have gone, most shops will insist on fitting a new TC at the same time unless they can flush the TC to remove any contamination.
What colour is the tranny fluid, does it smell burnt?
Old Sep 19, 2002 | 10:04 PM
KILLERLEXUS
how much to replace clutch bands???? the last time this happened, it was because i was low on fluids.....
Old Sep 20, 2002 | 03:38 AM
ChronoJ1's Avatar
ChronoJ1
If there's a whining sound coming from where the shift **** is....is that something related to transmission fluid?
Old Sep 21, 2002 | 11:33 AM
KILLERLEXUS
no whining sound..but it can drive when u first start it but, quickly begins to slip..thimk it might be something in the tranny fuids that cause it to clog when i drive, but unclogs by dropping bsck to bottom sfter shutting off car..
Old Sep 22, 2002 | 11:03 PM
London Bill
KILLERLEXUS;
Sounds very much like your box is fried, if you want a sixth or seventh opinion ring an autoshop.
RoMiLex
Oct 1, 2014 08:19 AM
DanielDD
Aug 1, 2014 10:02 AM
Fredster10
Apr 21, 2008 04:40 PM
Fastfwd
Aug 8, 2007 08:06 PM
themustafa
Jun 3, 2006 03:32 PM
