Problem with the sc......
Old May 31, 2011 | 02:33 PM
pokesmot's Avatar
pokesmot
Default Problem with the sc......
Ok so my sc300 is having some problems the car is lossing all power when I'm driving I'll hit the gas and it won't go anywhere the rpms just drop as I hit the gas pedal. The point ofthis thread is too see if any of u know what this problem could be
Old May 31, 2011 | 04:58 PM
Rommel's Avatar
Rommel
you may try to check the fuel lines like filter. is tune up done? if your engine still running even if you floored the accelerator pedal it maybe means there's not enough fuel going through.
Old May 31, 2011 | 05:22 PM
Joey-E's Avatar
Joey-E
It may be your ignition coils. Search threads see if it relates to your problem
Old May 31, 2011 | 06:51 PM
FutureSC's Avatar
FutureSC
What does it sound like when you stomp on the gas? Does it sound like a sort of puttering? Could be the coils
Old May 31, 2011 | 07:33 PM
pokesmot's Avatar
pokesmot
I thought it was the fuel filter so I changed that about 2 days ago an it stopped doing it then today it started doing it again today but It was alot worse
Old May 31, 2011 | 07:34 PM
pokesmot's Avatar
pokesmot
Yea it sorta does sound like it is puttering
Old May 31, 2011 | 08:04 PM
JDMmuscle's Avatar
JDMmuscle
CL Folding 200,000
Check the following...
Coils
Fuse's (all of them)
Spark plug wires
Spark plugs themselves, Make sure they are gapped right
Distributer caps
Leads
THEN
Fuel filter
Fuel pump ECU
Wireing harness to the FP ecu
Come back after you inspect all these parts and tell us what you saw
rbordeaux
Jul 18, 2018 08:58 AM
sc4lover
Nov 14, 2010 05:22 PM
page2two
Apr 2, 2008 03:50 PM
tuterz
Sep 24, 2007 11:43 AM
DroppedGS
GS - 1st Gen (1993-1997)
15
Apr 24, 2006 04:25 AM
