Bad ecu?
Old May 26, 2011 | 01:20 PM
SliC300's Avatar
SliC300
Default Bad ecu?
I have a 92 sc300 with an awkward problem: whenever I floor it, say in second gear, it won't upshift to third unless I competely let off the gas. It also does this when just revving at a stand still in park or neutral. Could this be caused by a bad ecu and a malfunctioning rev limiter? Or would this be something more tranny related such as old fliud in need of a flush? Other than that it shifts just fine and the gears change smoothly. im not too familiar with automatic transmissions, thats why I'm asking anyone with some kowledge on the subject. My biggest concern is that I am planning on on going NA-T, so I'm worried something might blow up before I get a chance to do a manual swap. Does anyone have any ideas as to what may be causing this?
Old May 27, 2011 | 07:29 AM
TechGreek's Avatar
TechGreek
If you're planning to go NA-T then you need to take your time and do ALL maintenance items. There's nothing worse than rushing into boost and blowing your money on the setup and then having issues later on.
Back to the issue at hand, it sounds like your Throttle Position Sensor is mis-adjusted. If you let off the throttle slightly at high rpm does it shift (i.e. only WOT won't shift).
Old Jul 10, 2011 | 09:11 PM
SliC300's Avatar
SliC300
yea, if I remember correctly when I let off the throttle it will shift, it was just WOT that wouldn't
ACCHRM
Sep 16, 2014 10:37 AM
Dtwillis5
Dec 3, 2013 09:50 AM
lex1220
Aug 23, 2011 09:45 PM
DRFT103
Dec 12, 2009 10:36 PM
convoy
SC400 / 300 Classifieds
Feb 14, 2007 09:57 AM
