drivers window help
Old May 9, 2011 | 04:34 PM
Farino81's Avatar
Farino81
Default drivers window help
my drivers window will go down but not up. It makes a buzzing noise everytime i press the switch. the passenger window works just fine. any suggestions?
Old May 9, 2011 | 04:44 PM
abounly's Avatar
abounly
It is your window regulator.
Old May 9, 2011 | 04:46 PM
Farino81's Avatar
Farino81
eventhough it still goes down? i had the same issue with my toyota pick up truck and i replaced the regulator only to find out it was the motor sticking
Old May 9, 2011 | 05:06 PM
abounly's Avatar
abounly
Yeah it will still go down. Thats what happen to mine too you hear the motor trying to work but the window doesnt go up and when you go over bumps the window slides down slowly.
Take the door panel apart and check to see if your regulator snapped, if lines are torn or anything if not you can check to see if its your motor
dtwins962
Jul 3, 2017 09:24 AM
Lexmex
RX - 1st Gen (1999-2003)
16
Jul 26, 2012 08:28 AM
LexusDaisy
Maintenance
Apr 5, 2006 09:33 PM
