Ok. Every common problem that could go wrong is wrong with my door. My hinge is making my door hang, The handle clip is broken (but I can open it from the inside), and my window can roll down but it dosnt have the power to go back up. So my parts list include.…………
1. Door hinge
2. Handle clip
3. Window regulator
Here are my questions.
What years are compatible with my 95?
How hard and how long does it take to replace the drivers side door hinge?
Is it smarter just to buy a whole new door and swap the parts over?
Please chime in if you've had experince with these problems and how you fixed them.
All doors from 92 to 00 should be physically interchangeable. The electronics may or may not be compatible mostly due to stereo system differences. If your car is a common color it may be cheaper to buy an entire door and hinge as long as everything works in it and the hinge is good. Then if your door is straight enough you could resell it.
Unfortunately my car is platinum silver metallic. I highly doubt it if I could find a door that matches. I think I'm just going to get a full door and switch parts.
