tallest gear ratio?
Old Apr 19, 2011 | 05:29 PM
poorsupra's Avatar
poorsupra
Default tallest gear ratio?
well i have been looking around to find the tallest gear ratio available for an sc400. looking to drop in a 550-600whp LS/t56 combo and im looking to get in the 2.73 gear range. this will be more of a top speed specific car. are ring gears available in this size? or close to? which leads me to my next question, how much HP realistically can the diff hold? a ford 9" section custom fabbed would be an idea, but i have not seen any info on this, so im assuming there must be a lexus diff that can hold power with some mods. any info is appreciated. thank you
Old Apr 19, 2011 | 06:38 PM
SChema's Avatar
SChema
I believe the TT TRD rear diff is a 3.27. Not quite what you're looking for but basically a bolt-on. There are two, a 10 bolt and a 12 bolt. You'll need a 10 bolt to fit the SC housing. Not sure if there's a variance in ratio between the 10 bolt and 12 bolt.
If you have the funds or the means to do a complete Ford 9", the TT swap is perfect for you. The one in my friend's car has held up to over 1100 horsepower and over 900 torque from a roll or dig, it takes is all.
Old Apr 19, 2011 | 07:16 PM
Wicked SC's Avatar
Wicked SC
The gearing has really nothing to do with the TRD Diff.. The TRD diff is a true limited slip with clutch packs and beefier spider gears inside to wistand the abuse of high powered cars..
The tallest gearing would be 3.13 which is the USDM TT 6 Speed diff..
Old Apr 19, 2011 | 08:24 PM
SChema's Avatar
SChema
^, I know.
I was suggesting the TRD diff over the Ford 9" in terms of holding the power and torque, not because of it's gearing.
Old Apr 19, 2011 | 09:15 PM
snowfox444's Avatar
snowfox444
I wanna put a 503 ring gear in my sc400. I wanna burn more rubber
sc4shelby
12
Jan 22, 2015 12:21 AM
charley240
Jul 27, 2012 09:47 PM
ReganSC300
Apr 27, 2011 01:47 PM
tampa mike
Nov 28, 2009 07:49 PM
JBrady
Feb 20, 2003 10:01 AM
