crank pully bolt... please help
Old Apr 11, 2011 | 10:03 PM
good2go's Avatar
good2go
Originally Posted by turbodremz
I see alot of wrong info going in here...
All you need is this:
http://cgi.ebay.com/ebaymotors/Schle...motiveQ5fTools
2-breaker bars, and one cheater-pipe. I had the same issue with my crank bolt, but that little tool solved everything, and I will never sell the one I have even though I no longer have a 1jz/2jz.
Sorry mods for the ebay link, but I had to cut the bs short and get to the point.
Originally Posted by shern
I've been wanting to show my solution for quite some time. Just some u-channel steel from home depot (thick and long one, no homo). Holes cut for socket and screws for crank. A breaker bar with pipe and this and it popped off instantly. Just make sure you tighten this bar to the pulley or you'll bend the bolts. Worked like a charm and cost $10 bucks!
+1
The added beauty of these tools is that:
a) you totally avoid damage to the pulley/damper
b) you can leave the radiator in place
c) (perhaps the most important) you can securely hold it for properly re-torquing it.
EDIT: added c)
Old Apr 12, 2011 | 06:32 AM
lookEVO's Avatar
lookEVO
I have the baddest Snap-on impact and i never have problems. hell my 3/8 impact can do almost anything else well.
Old Apr 12, 2011 | 08:34 AM
CP_Ree's Avatar
CP_Ree
The starter trick worked every time.
Old Apr 12, 2011 | 09:03 AM
Ltec's Avatar
Ltec
X u need a chain wrench just like the one I the pic someone set ..& 22mm 3/4 " socket ...3/4 breaker bar ..5ft steel pipe to go over BB. Set chainwrench on crank pulley to lock off on ground ...protection on fender ..put bar on pull from top for ure life in Fla they get tight don't slip remove airbus &rad.. good luck
Old Apr 12, 2011 | 09:17 AM
broda805's Avatar
broda805
http://www.youtube.com/watch?v=-fiHr...4F4F94E987483D
heres the vid im going to use when changing out my timing belt i cant remember if its in part 2 or 3 but he has a nifty tool he uses for the crank bolt
Old Apr 12, 2011 | 09:41 AM
good2go's Avatar
good2go
^^ it is in the Part 2 vid, and the tool he shows there is the same type as the one turbodremz linked to.
Old Apr 12, 2011 | 10:45 AM
tinman's Avatar
tinman
I had the same problem some years ago. Someone at Toyota thought it would be really funny to torque this down to 600 ft lbs. Most of the 2JZ motors have this issue. The Schley 64300 is totally the way to go, or you can find an impact wrench with 600+ ft lbs. I had an air powered impact wrench putting out 450 and it wouldn't budge. I ended up getting one that went to 750 and it came off easily. This bolt is a total pain.
Old Apr 12, 2011 | 11:27 AM
FutureSC's Avatar
FutureSC
I had this problem last year. I used a chain wrench with a cheater bar to hold the pulley and a breaker bar with another cheater bar to get the bolt. It was the biggest PITA I've come across. That thing was welded on.
Old Apr 18, 2011 | 01:33 AM
quaiduhm's Avatar
quaiduhm
Originally Posted by GSteg
What impact did you use that you can't get it off? Very rarely do I encounter a 2JZ crank bolt that cannot be taken off with an air gun.
I used a 1 inch ingersol, and it didn't come off. I did finally get it off with a chain wrench breaker bar and 2 8 foot sections of pipe.
Old Apr 18, 2011 | 10:06 AM
GSteg's Avatar
GSteg
That's surprising. Usually my 1/2" Ingersoll takes it off without problems. What air lines are you running? I'm surprised you could even fit a 1" impact in there
Old Apr 18, 2011 | 11:10 AM
quaiduhm's Avatar
quaiduhm
Yeah it wasn't fun we had to basically take apart the front of the car. I'm not sure what airlines we used. My brother works at a shop and we used the 80 gallon compressor they have there.
vanges300
Apr 17, 2013 07:24 AM
HeisLegend
Mar 2, 2010 08:50 PM
kpopil
RX - 1st Gen (1999-2003)
Jan 15, 2009 09:30 AM
Project300
Jun 2, 2005 08:57 AM
