Turbo Kit
Old Apr 9, 2011 | 06:04 PM
drastic95's Avatar
drastic95
Default Turbo Kit
I know I'm gonna catch some slack for starting this thread but I looked for an established one and couldnt find it. I have a 95 stock 2jz with a factory 5 speed tranny. The motor only has 80k on it so I feel a little reluctant yanking a perfectly good low mileage motor to do the swap. I heard the E-Bay turbo kits are garbage, is there any decent kit for around 1000-1500? I'm llooking for at least 300 hp....any suggestions?
Old Apr 9, 2011 | 06:40 PM
VanillaSC's Avatar
VanillaSC
http://store.driftmotion.com/static/...-1turbokit.php
Old Apr 9, 2011 | 07:45 PM
maynanator's Avatar
maynanator
this kit requires a tune and charge piping, fmic, and a bov.
Old Apr 9, 2011 | 09:44 PM
MikeNguyen's Avatar
MikeNguyen
upgrade day by day. NA-t? I would do GTE intake manifold, and turbo headers
Old Apr 9, 2011 | 10:37 PM
lookEVO's Avatar
lookEVO
xs-power kit is decent for the price if you are looking to go budget. 1590 shipped. check out clubna-t.com
Old Apr 10, 2011 | 03:48 AM
drastic95's Avatar
drastic95
Thanks for the input.
Old Apr 10, 2011 | 07:09 AM
F4A22's Avatar
F4A22
Ebay cast manifold
Genuine Garret 61mm or bigger non bb(for price)
Name brand oil feed,return lines and fittings.
38mm to vband adapter
Tial 44mm wastegate
Tial blow off valve
Ebay intercooler and piping kit
Map ecu
Jdm 440 injectors
That should put you under $1500 new or alot cheaper used and be alot better off than any ebay kit out there.The cheap tubular manifolds need bracing and cutting corners always costs more in the longrun.The turbo setup on my car is similar to above except its a smaller turbo and a GTE engine.
Old Apr 10, 2011 | 09:02 AM
drastic95's Avatar
drastic95
F4A22, I noticed your in FL, Would'nt happen to be SOFL would it? I'd like to take my car to someone thats familiar doing these setups.
Old Apr 10, 2011 | 11:12 AM
F4A22's Avatar
F4A22
Sorry i'm in Bartow which is almost in the middle of the state.Theres quite a few turboed sc's down there i'm sure you can find help easily.If you need guidance or a souce for parts pm me.
Old Apr 10, 2011 | 11:21 AM
DuWerke's Avatar
DuWerke
Does this manifold clear the dizzy?
Old Apr 10, 2011 | 01:18 PM
SChema's Avatar
SChema
In order to do GTE intake and exhaust manifolds, you would need to do a GTE head as well.
gman44116
Performance
Dec 20, 2009 10:58 PM
bugeyeGS
24
Nov 9, 2008 07:56 AM
breed
SC400 / 300 Classifieds
14
Apr 18, 2008 12:05 PM
SC300_704
Jul 16, 2007 11:34 PM
prjctSC300
Oct 9, 2005 07:48 PM
