power seat
Old Mar 30, 2011 | 05:42 PM
jstemmy198's Avatar
jstemmy198
Default power seat
i have 95 sc400 my power seat the passer side stop letting back on on side it go back a little then it go side ways and stops any one know what it could be
Old Mar 30, 2011 | 07:36 PM
brad11140's Avatar
brad11140
Could be a bad power seat ecu. Remove the seat if you can. It's on the bottom
Old Mar 30, 2011 | 07:49 PM
BenStoked's Avatar
BenStoked
CL Folding 1,000,000
had this happen to me.
lemme guess. it seems to pivot on the door side, the inside moves, while the outside stays in place?
I had to pull the seat out (I have absolutely no clue how I didn't break the seat in the process), I found a little white cap had unscrewed it's self. under where the cap is is a bearing, and a gear that goes to the outside track. since the cap wasn't holding the bearing where it should be, the gear backed out, and wasn;t contacting where it should to move the track.
Good luck.
Old Mar 30, 2011 | 08:40 PM
meangreen1's Avatar
meangreen1
Ill be selling some seats as a whole or for parts this weekend. Let me know.
Old Mar 30, 2011 | 10:28 PM
dwebb99's Avatar
dwebb99
What BenStoked said is a common problem and a easy diy fix. Remember you can manually move the seat forward and backward.....there is a DIY on how to manually move the seat (allows you to remove seat)...just do a search
GKLCPA
Jun 1, 2022 05:52 AM
RedCab
Jun 4, 2019 07:30 AM
tymeboy
Jun 16, 2018 12:02 PM
AlblineLex
IS - 1st Gen (2001-2005)
Feb 5, 2014 01:42 AM
okbobbo
May 24, 2010 03:12 PM
