Electronics Shutting Off
Where did you test? Battery posts? Borrow one and test from an end point such as power wire and ground going to the radio, or the cig lighter. Just because you're charging at 14, and the batt is at 14, doesn't necessarily mean the accessories that are having problems are getting 14, you may have resistance in the circuit somewhere causing a drop in voltage to the harness going to the cabin of the car. Other than that, pull the lower dash panels and look for ground points, remove, clean, apply vasoline...(yes, vasoline) and tighten.
, and then i will let you know what i find. Also would a ground cause the car to shut off too?
lowKut
Dec 19, 2009 10:05 PM
charmz
Jul 7, 2008 08:19 PM
