Idle problem
Old Jan 22, 2011 | 06:09 AM
Chevyguy's Avatar
Chevyguy
Default Idle problem
1995 SC400
My son's car has a strange problem, and being a Lexus I don't know where to begin. As my name implies, my automotive experience is in the Chevy world. He advises that his car's idle is so low that the car will die on him at stoplights. When the AC is on, the car will idle fine. Can anyone point me in the right direction for a repair? Been unable to find a book on the car anywhere and as my son no longer lives with me I don't have the car available to tinker with.
Old Jan 22, 2011 | 06:59 AM
scviolence's Avatar
scviolence
i know on the sc300s u can adjust the idle up or down on the throtle cable but im not sure about the sc400's theres probably a lil arm u can adjust like ours...good luck
Old Jan 22, 2011 | 09:09 AM
good2go's Avatar
good2go
Sounds like it may be IACV related. There's quite a bit on threads here discussing it (advanced search is best bet) and there are also free copies of the factory manuals online that you can download (again, use advanced search).
G/L
Old Jan 22, 2011 | 11:48 AM
Chevyguy's Avatar
Chevyguy
Thanks folks, I'll check into them.
Old Jan 22, 2011 | 05:19 PM
XxSC400xX's Avatar
XxSC400xX
Sounds like idle air control valve. Link to help you diagnose. http://www.planetsoarer.com/IAC/iac.htm
Old Jan 24, 2011 | 05:23 PM
itsthematt's Avatar
itsthematt
Try unplugging the ERG. I had similar problems, although mine never actually at a stoplight, and unplugging the ERG fixed my situation. Note that the check engine light will come on from doing this. However, it is no need for worries.
If that is not your problem I would check into the IAC or the fuel pump ecu.
Old Jan 30, 2011 | 10:34 AM
Meanshyguy's Avatar
Meanshyguy
I disconnected my EGR and didn't get a check engine light, is that normal?
wan8dan
Sep 3, 2013 05:31 PM
Lexus082
Jun 4, 2012 09:26 PM
clean
Jul 17, 2007 07:23 PM
AUGuy21
Performance
Jun 12, 2006 01:37 PM
aumsc400
Dec 31, 2005 05:56 PM
