turbo help!
sooo i was drilling my oil return line out, and the piece fell in there. how the hell do you get off the lower oil pan. (piece is right there on the baffle) i took all the bolts out and i have gone around the edges with a razor to get as much sealant off as possible....idk wth to do next but my patience is wearign thin realllll quick now lol....SOMEONE PLEASE GIVE ME THE KEY TO THE OIL PAN!!
http://forum.clubna-t.com/showthread.php?t=594 i tried doing the jack method here but it only helps if u loosen the pan already for clearance...
tahnks for any help guys.
sorry to see your issues but to remove that pan you need a small piece of 2x4 and knock around the perimeter of the pan of course with eng jacked up away from the craddle , it might be easier to just remove eng and do the pan properly
lmk if you want me to do the work for you , we remove eng in less than 2 hrs and back in the car by the end of the day
