Running 2jz without Ac compressor
Old Dec 14, 2010 | 10:48 PM
navazsc3's Avatar
navazsc3
Default Running 2jz without Ac compressor
I've searched all night with not much info
What are my options to run a 2jzge without an Ac compressor
The problems I ran into is that the power steering pump mounts onto the Ac compressor as well as the motor.
And what drive belt size should I use?
I know somebody has already done this, thanks
Old Dec 15, 2010 | 07:35 AM
99SC42's Avatar
99SC42
Use a TT P/S pump and you will be fine.
Old Dec 15, 2010 | 09:24 AM
navazsc3's Avatar
navazsc3
It's a 1992
Old Dec 15, 2010 | 09:34 AM
99SC42's Avatar
99SC42
it doesn't matter if you wanna remove the A/C compressor you will need a TT P/s pump and reservoir.
Old Dec 15, 2010 | 07:14 PM
navazsc3's Avatar
navazsc3
Originally Posted by WsKSilent
What year?
I noticed there's 2 diagrams for the compressor.
On my '92 I used NBH25060747 Serpentine Belt from Napa to delete the compressor.
what did you use to support your power steering pump?
the one bolt that holds the power steering pump to the motor?
or did you leave the ac compressor attached to the motor/power steering pump to help support the ps pump and just not have the belt run it?
sibanez
Sep 1, 2016 12:38 PM
1slow240
Dec 25, 2013 09:46 PM
MrHolister
SC400 / 300 Classifieds
Aug 7, 2010 04:25 PM
curtsutton
Sep 3, 2009 09:56 PM
