Oil in spark plug valley again!
So I am having this difficulty where I dont know where this oil is coming from! First time I did a tune up since owning the car for a little over a year, there was massive amounts of oil in my spark plugs which caused a missfire.
6 months after the tune up and smog is due since i got hit with a random check... SAME PROBLEM!
Tune up consisted of:
NGK I-platinum spark plugs
NGK Wires
Valve gasket
Throttle body gasket
Distributor rotor and cap
-Old plugs from 1st tune up seem fine still just dirty from the oil
I was wondering if any one had the same issue and was wondering where could this oil be coming from
Thanks
NGK Wires
Valve gasket
Thanks
The oil would have to climb uphill and backwards. If it were wind sprayed, you'd definitely see it all over the place.
I kept on getting oil in the valley, even with new gaskets. Until one day where I looked at the design and found out that there are ***** on the inside of valve covers. I ground a little bit of the ***** and used some gasket maker in addition to the gasket, then torqued the bolts well. Leaking never came back and my valley looks clean as a whistle.
[QUOTE=madmax98;5954422]I kept on getting oil in the valley, even with new gaskets. Until one day where I looked at the design and found out that there are ***** on the inside of valve covers. I ground a little bit of the ***** and used some gasket maker in addition to the gasket, then torqued the bolts well. Leaking never came back and my valley looks clean as a whistle.[/QUOTE
Yea its probably the same problem...going to try that
I'llKeep yall posted
did grounding the ***** fix your problem as well. I am pulling plugs and there is not a ton of oil in there, but its there. And when I pulled the plugs the threads are soaked with what I thought was gas but I am more inclined to think its oil.
its most definitely oil...i order a complete gasket kit this time which included valve cover grommets instead of just the valve covers and it did the job...order the complete kit not just the valve covers...good luck
njamal
Oct 6, 2003 12:02 PM
