Need some speedo/tech help!!!
Old Nov 9, 2010 | 02:27 PM
mk1973's Avatar
mk1973
Default Need some speedo/tech help!!!
I'm new here, just bought a 92' SC300 love the car! it had 3/4 needle burnt out so i thought I would use the DIY how to on the forum. the needles came out great. the problem is no neither the tech or speedo work keep in mind both worked fine before I touched it. any idea's would be great, i'm at a lose.
Old Nov 9, 2010 | 03:01 PM
Slow_Sc3's Avatar
Slow_Sc3
forgot to plug something in.... did you get the two strips at the bottom? they slide in and then you press the plastic tab down to lock them into place.
Old Nov 9, 2010 | 03:05 PM
mk1973's Avatar
mk1973
All ribbon cables are in and sucure, I notice when I start the car the tech will move almost like it's stuck. it dose not move freely. does the little spring with the two power pins have to be set in a certan why during the reinstall of the needles? Is there a needle reinstall how to?
Indigo45
Mar 21, 2017 04:35 PM
luisykari
Jun 24, 2012 06:11 PM
RedSC
GS - 1st Gen (1993-1997)
May 27, 2010 01:13 AM
jdm93400
Jan 27, 2010 08:29 PM
92LexusSC4
Feb 16, 2006 12:10 PM
