Cold start rattle
Old Nov 8, 2010 | 01:12 PM
stockhatch's Avatar
stockhatch
Default Cold start rattle
My old GE motor did this, and so does my GTE. When I start it for the first time each day, the SC will clatter briefly(approx 1/2 sec or less). It sounds like a diesel to be honest. I used to drive an 04 Jetta GLI with a 1.8T and it did the same thing.
Anywho, I wonder if anyone else has this, or are my rods about to make windows in my block? Once the oil light goes off it shuts up, but I do wonder if this is a classic sign of impending failure with theses motors, or just something high mile examples do.
FWIW, the motor runs great, boosts great, and is very silent except for the initial start of the day. Once you start it one time, all subsequent starts are quiet and uneventful.
I heard something about oil filters and their check valves being sucky, which allows all the oil to drain back to the pan overnight causing cold start starvation. Any insight on this? I run a vanilla Purolater filter if that helps.
TIA
Old Nov 8, 2010 | 02:22 PM
good2go's Avatar
good2go
Originally Posted by stockhatch
My old GE motor did this, and so does my GTE. When I start it for the first time each day, the SC will clatter briefly(approx 1/2 sec or less) (THIS IS TYPICAL). It sounds like a diesel to be honest. I used to drive an 04 Jetta GLI with a 1.8T and it did the same thing.
Anywho, I wonder if anyone else has this, or are my rods about to make windows in my block?(I DOUBT IT) Once the oil light goes off it shuts up, but I do wonder if this is a classic sign of impending failure with theses motors (MUCH LESS THIS), or just something high mile examples do (MORE MORE LIKE THIS).
I heard something about oil filters and their check valves being sucky, which allows all the oil to drain back to the pan overnight causing cold start starvation. Any insight on this? (THAT'S NOT WHAT DOES IT. YOUR OIL DRAINS REGARDLESS) I run a vanilla Purolater filter if that helps (NO, IT DOESN'T. GET A DECENT FILTER! ).
TIA
see comments within
Wix, Napa Gold, Mobil1, Amsoil, etc . . . . .but no FRAM or Purolator "vanilla" filters, PLEASE!
$.02
Old Nov 8, 2010 | 02:32 PM
stockhatch's Avatar
stockhatch
Hmmm, so filter check valves wont effect it at all? I will look into another filter. I assume you dont like the Purolator filter based on its actual filtration and bypass qualities?
At any rate, I guess it's good to hear that it is typical. You don't see many threads with people complaining of the noise.
Old Nov 8, 2010 | 02:36 PM
stockhatch's Avatar
stockhatch
Just FYI, this is where I read about the filter possibly being the issue...
http://www.supramania.com/forums/sho...t-cold-startup
Old Nov 8, 2010 | 04:41 PM
JOHIII's Avatar
JOHIII
My car does the same thing now that it is colder. It's only for a half second or less and it's only the first startup of the day. I read another topic here that said it's just too much RPM too soon. I've got a Toyota filter on mine.
Old Nov 8, 2010 | 07:05 PM
good2go's Avatar
good2go
Funny they mention the WIX though, because I've been using them for some time now and it made absolutely no difference. Seriously, I doubt there's an oil filter out there that would hold oil for an extended period of time. Google it, you will see comments on nearly every forum for every make and model of car. It's just a factor of wear and lack of oil pressure at the instant of startup. If you are worried about it and want to sacrifice your starter/battery, you could rig up an ignition/fuel defeat switch and let the starter run a while to pump up some oil pressure before flipping the switch and letting the engine fire up; but seriously...who does that?
Old Nov 8, 2010 | 08:44 PM
1WILLY1's Avatar
1WILLY1
do u guys mind sharing your mileage on your engines-----just curious is all-----i wouldnt expect5 this sort of thing from a lower mileage engine --im assuming your are on the high side---thanks
Old Nov 8, 2010 | 09:15 PM
good2go's Avatar
good2go
Originally Posted by 1WILLY1
do u guys mind sharing your mileage on your engines...
How dare you! That's highly personal information.
j/k 130K
Old Nov 8, 2010 | 11:15 PM
LEX_MAN's Avatar
LEX_MAN
mine does it too, i got 250xxx miles.
Old Nov 9, 2010 | 04:09 AM
lexforlife's Avatar
lexforlife
relax
it just the wrist pin making that noise until it gets proper oil up there .. not causing any damage .. if you use a syn oil like mobil 1 it tends to leave a thin oil film on the wrist pin and tends to quiet it down or eliminate it all together
Old Nov 9, 2010 | 06:11 AM
stockhatch's Avatar
stockhatch
Mine supposedly has 100k MILES on it according to JHot. That is a lot of miles for a JDM engine, but overall it seems healthy. I run Mobile 1 10-W30. I'm not too worried about it since it goes away pretty much immediately. Just curious if others have the issue too since you don't really see many threads addressing it.
Old Nov 9, 2010 | 08:16 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
In my tuning adventures I found my car making that noise in cold weather first starts when there wasn't enough start up fuel during cranking (cold start injector duration) or immediately following cranking (start up fuel to stabilize idle). making the mixture a little richer during the whole start up process got rid of the noise completely for me, but i doubt you can do that with the stock ecu. I tried 5w30 and 10w30 full synthetic didn't make much a difference except change the tone a little maybe. I have no noise even when my little oil light decides to stay on for a couple seconds towards the end of an oil change period. before i adjusted the fuel last winter I thought my engine was going to rattle itself apart during cold starts. every other start the rest of the day never made a noise.
Old Nov 12, 2010 | 08:19 AM
JOHIII's Avatar
JOHIII
Smile
150K on mine. 5W-30.
Old Nov 13, 2010 | 09:11 AM
JDMSoarer5's Avatar
JDMSoarer5
192K on mine. Castrol Edge 5W-30
skifanatic
GX - 1st Gen (2003-2009)
Dec 29, 2017 01:27 PM
RCF100
RC F (2015-present)
15
Mar 10, 2017 03:18 PM
Todd Edge
Jan 17, 2012 10:49 AM
mikewpu04
May 9, 2006 02:04 PM
