*1992 Sc 300 cluster replacement*
A friend gave me a cluster from an unknown year car. When I installed it I noticed that the Tach is reading too high, and the Speedo doesn't go much higher than 20mph even on the freeway...
1. Does it need calibrated or reset somehow?
2. If I have to replace it what years can I use ?
Thanx in advance
Wayne
Thanx in advance
Wayne
Thank you sir... Correct me if im wrong please...
I can use a sc 300 from any year, but not an sc400 because it wont give me accurate readings ?
Is that correct ???
Peace and Thanx
Wayne
Is that correct ???
Peace and Thanx
Wayne
Yes sir make sure you get a sc300. I was able to put a 99 sc300 cluster into my 95 with some wiring of course. I think you would have to replace both the tach motor and speedo motor to get it working correctly.
If your going to put a 99 cluster into your pre 97 youll need to repin or splice wires from the 99 plugs into your car.
https://www.clublexus.com/forums/sc-...-96-sc300.html
Let me know if you are really going to do this mod i have more info.
AllBoutDaZ
SC400 / 300 Classifieds
Dec 10, 2004 02:54 PM
