Ebay motor experience
Old Sep 29, 2010 | 10:08 AM
Sammosti's Avatar
Sammosti
Default Ebay motor experience
Guys,
First of all, I did search the site and couldn't find a straight answer (or I sucks at searching!) Anyway, I am in the process of acquiring a 1jz + 5 speed for my swap, and ebay is the first place came to my mind. There are few companies (JDM Engine zone, Japan power, JDM planet...etc) selling on ebay and I am hoping to find out what people's experience on their purchase.
Also, if anybody have recommendation on a particular company, I would love to hear.
Thanks
Old Sep 29, 2010 | 10:14 AM
kwg's Avatar
kwg
i'd look around for a local place that can source one for you and have them do compression/leak down tests. if not i'd call around and find a a reputable company i can deal with over the phone. although there are all these things protecting the buyer im not too big of a fan of stuff from ebay especially something like an engine. might end up being a huge hassle and i rather avoid the headache
Old Sep 29, 2010 | 12:23 PM
t70 supra's Avatar
t70 supra
i'm def not a fan of buying ebay motors. most of the companies use 2-3 difference names to balence out bad and negitive comments. also most of the motors u buy are junk thats left over from the last of the container shipments thats why thier so cheap. there is a good shortage of good jz motors as of a few months ago. im not saying all are junk but is a 50/50 chance. i got my motor from kaream at jspec auto it came in great condition. had the tune up already done on it just missing a timing belt. had the igniter, COMPLETE uncut harness, ecu's maf sensors nothing was broken at all just a bent shifter on the tranny but it shift smooths so far.
i would get a motor from some 1 you have talk to and built a repore with cause if you buy 1 of those ebay motors i read stroies where people got analed by the company thats why i made sure i called around and talk to company.
best thing is talk to memebers on here and where they got thier motor from
i could reccomend to u
g-speed
panda garage
jhot
jspec auto
or have you checked craigslook or surpaforums , from time totime thiers a motor on here for sale i would also try surpamania.com
Old Sep 29, 2010 | 12:26 PM
Shanty's Avatar
Shanty
If you don't mind the drive, there's plenty of shops down in Jersey that will get you a good engine and do the install for you.
Old Sep 29, 2010 | 12:43 PM
abounly's Avatar
abounly
jhot hands down
Old Sep 29, 2010 | 01:18 PM
t70 supra's Avatar
t70 supra
I've seen a jhot motor in bad condition
Old Sep 29, 2010 | 01:52 PM
Sammosti's Avatar
Sammosti
More info please! I don't mind the at all.
Old Sep 29, 2010 | 01:53 PM
stockhatch's Avatar
stockhatch
I have a jhot motor, and it SEEMS ok so far. Have just done a couple startup heat cycles so far, so no boosted pulls or anything yet.
PS, g-speed closed shop months back from what I recall.
Old Sep 29, 2010 | 03:49 PM
t70 supra's Avatar
t70 supra
I know gspeed closed in June but the owner gets motor on the side and thier all hand picked
Old Sep 29, 2010 | 07:09 PM
StiCk3's Avatar
StiCk3
i wish i would've redone my swap from a reputable dealer, the one i got from JDM power Inc. came with a missing MAP sensor plug, bad alt, bad ps pump, bad rear turbo, a dent in the oil pan...you get the picture.
Get it from a reputable place like JHOT. I should've waited for the next JHOT shipment but i got impatient and paid more than i should've in the end.
Old Sep 29, 2010 | 08:08 PM
ClearP's Avatar
ClearP
Ebay motors are pretty bad, I've heard nothing but good things about Jhot, I however would try and find one locally so you can do a leakdown and compression test.
Old Sep 29, 2010 | 08:47 PM
Tphix's Avatar
Tphix
Ive used both jdm enigine depot and jdm engine crops and the engines were just fine other than a couple broken clips on one wire harness.
Old Sep 30, 2010 | 04:44 AM
t70 supra's Avatar
t70 supra
Try jpec auto my motor was clean and in good condition they gave me pics of everything I asked for then worked with me as far as pricing and what I wanted no broken pieces on my engine or harness at all
Old Sep 30, 2010 | 07:43 AM
white96SC's Avatar
white96SC
Originally Posted by Sammosti
Guys,
Thanks
I wouldn't trust eBay at all...most of the time you see a "Soarer 1JZ", you think it'll be a direct swap, just extend the harness right? But its usually a supra/chaser 1JZ. So no you have more worries about wiring and god knows whats wrong with it
Go on supraforums and look for a MKIII supra 1JZ thats local to you and swap the supra harness for a soarer one (and you have to extend the soarer harness). I dont think theres much stuff for the soarer electronics though (EMS, Standalone, Piggyback ECU, etc.)
As for the r154, Look for one out of a chaser/soarer(<--harder to find). Look on here, Supraforums, or My.IS.
I did some research and found out that the r154 (with extended shifter) gets swapped into IS300's with automatics. So searching on My.IS I found a soarer r154 that came out of an IS300 for a good price and it looked alot cleaner than most r154's ive seen.
EDIT:: Also have heard nothing but good things about JHot....Stay away from Osaka tho, if you ask for a Soarer Motor they'll just send you an MK3 1JZ anyways
Old Sep 30, 2010 | 08:11 AM
FuMoFFuTT's Avatar
FuMoFFuTT
I live in Montreal and majority of the engines come from here,maybe I can help you do the transaction.
Bizzy2001
CL of Southern California
Mar 25, 2012 06:07 PM
LSmith
Oct 21, 2008 04:11 PM
beachfront
May 25, 2007 10:29 PM
Just4show
Oct 26, 2006 08:04 AM
Pheonix
Apr 25, 2006 04:13 AM
