Help trunk wont open
Old Sep 25, 2010 | 10:36 PM
jiggahwh0's Avatar
jiggahwh0
Default Help trunk wont open
so i was messing around with the valet key lock for the trunk to see if it still works and it got stuck and now i cant open the trunk anyways on how to open it?
Old Sep 25, 2010 | 10:42 PM
masagsxr's Avatar
masagsxr
Huh? I don't think the Valet key will open the trunk at all when double locked from main key. Can you open from the latch inside the car? Maybe you pressed on the lock switch from the inside? You have to unlock that too with the main key.
Old Sep 26, 2010 | 08:06 AM
scviolence's Avatar
scviolence
if u need to desperately open it pull the bottom dash panels off just a few screws, and then unplug the switch plugged into the trunk release. get a paper clip or whatever there should be a blue and black wire on the two pin plug from the trunk switch. touch the paperclip to both sides and the trunk will pop open. good luck...
SH212
Sep 27, 2024 05:28 AM
Andyb63
Sep 9, 2015 02:16 PM
Pwyll
Dec 17, 2006 03:08 PM
Flufferiou
Oct 1, 2006 10:28 AM
