slow start.
Old Aug 10, 2010 | 08:00 PM
imDementeD's Avatar
imDementeD
Default slow start.
so i noticed today when i came to a red light i could let off the brake and the car wouldn't move forward a bit....not a big deal heavy car etc..but then when i went to take off it was almost as if the brakes were being applied..no the ebrake isnt up or anything like that..
so after two red lights i started getting nervous..i went a head and manually put it in first gear..let off the brake the car idled forward like it should..went to take off perfect no issues?..
so im assuming the car isn't down shifting to first gear when i hit a red light..
what would cause this?..
honestly its my first automatic car in probably 5yrs or so and never had any issues with my last one(98 honda accord fwd) so im a little lost when it comes to this..any help or insight would be appreciated..
my tranny mechanic friend said sounds like a solenoid but id like some more advice from the sc community..
also no CEL's etc.
Old Aug 10, 2010 | 08:23 PM
romycha1's Avatar
romycha1
Your O/D Off light doesn't flash?
Sounds like my car. My trans valve solenoids are bad, so it doesn't downshift when I come to a stop... I have to manually shift it. Your trans might be experiencing the same thing.
Old Aug 11, 2010 | 05:19 AM
imDementeD's Avatar
imDementeD
as a matter of fact it was flashing earlier when i was driving then it stopped..usually it doesn't but that is the 2nd time the OD has flashed on me.
Old Aug 11, 2010 | 07:25 AM
romycha1's Avatar
romycha1
Do you know how to put your car into diagnosis mode by shorting out T1 and E1?
Well, if you do, do that and turn the key to the start position. Your O/D Off light should flash a few times have a short pause, then flash a few times again... then a longer pause, then the flashing will start over.
Count how many times it flashes (the first time), wait for the short pause, then count how many times it flashes (the second time).
If you're having a solenoid issue, it should flash 6 the first time and 2 or 3 the second time. 2 if it's valve solenoid one, 3 if it's valve solenoid two.
Hope this helps, PM me if you I'm not being clear...
Old Aug 11, 2010 | 11:11 AM
imDementeD's Avatar
imDementeD
awesome man i really appreciate that thank you
Old Aug 11, 2010 | 11:58 AM
romycha1's Avatar
romycha1
No problem, let us know what you find.
Old Aug 12, 2010 | 02:45 PM
imDementeD's Avatar
imDementeD
well it seems to being going bad but not quite yet..this happened twice total so far but today drove it a few different times and it down shifted and took off fine..no flashing O/D off or anything..and it only did this on the way to my friends house the night posted..on the way back i didnt catch a single light to know if it was occurring on the way home(the way there the O/D off light flashed for a bit of the drive but went off and never came back on, on the way home) so i guess ill just let it be for now but know what to look for if/when it comes back
Old Aug 12, 2010 | 06:16 PM
romycha1's Avatar
romycha1
Yeah, I'm just living with mine for now, and just shifting manually. I have another trans I can install, but I'm hoping to collect all my 5speed parts soon.
Old Aug 12, 2010 | 07:19 PM
Kato1978's Avatar
Kato1978
what do you mean when you say your shifting manually im new to all of this car lingo, cuz my o/d light flashes and takes off slow also
Old Aug 12, 2010 | 08:09 PM
FireCode's Avatar
FireCode
He is dropping the shifter down to the 1, then shifting it up to the 2 which is second gear like you were driving a manual car.
Old Oct 31, 2010 | 10:44 AM
dreamsc300's Avatar
dreamsc300
exact same thing is happening to my car, it feels like i'm starting out in 3rd gear so i have to manualy shift, does anyone know how to replace your solenoids?
Old Oct 31, 2010 | 11:41 AM
romycha1's Avatar
romycha1
I've never done it... but it's pretty straight forward if you're somewhat mechanically inclined.
The hardest part is probably dropping the fluid pan for the trans. After that, the solenoids are in view. But I've heard someone mention that the white plastic mounts the solenoids are in can break if you are not careful taking them out.
Old Nov 1, 2010 | 06:55 PM
dreamsc300's Avatar
dreamsc300
well im 17, so i might include my father on this project
SPhoto
15
Mar 4, 2014 05:36 AM
betsy
Feb 2, 2011 03:11 AM
Sweetser
Dec 7, 2006 09:28 AM
Iron Sheik
18
Jul 29, 2005 08:53 PM
