What ever happened to...? DEXTRON II
Old Aug 7, 2010 | 07:14 PM
Cyclenby's Avatar
Cyclenby
Question What ever happened to...? DEXTRON II
I need to fill both the fan fluid (never heard of such a thing before) and power steering fluid on my 1992 SC400. Manual calls for DEXTRON II - I have not had an older car in several years so I took a trip to AutoZone and wondered what ever happened to all the AT brands and options There use to be so many choices now there are none... At least good old motor oil still comes with a few choices. SO I GUESS IF YOU OWNED STOCK IN A AUTOMATIC TRANSMISSION FLUID MANUFACTURING PLANT YOU WOULD BE BROKE TODAY.
Question for you experienced DIY types: I purchased Valvoline DEX/MERC "For Vehicles requiring DEXTRON-III/MERCON" RECOMMENDED FOR MOST GM< FORD< & SELECT IMPORTS (back says good in Acura, Infiniti, and Honda (exceeds performance standards all previous DEXTRON))
** Is this alright to use across the fluids to include AT calling for DEXTRON II? What does everyone use???
Old Aug 7, 2010 | 07:21 PM
TankMR's Avatar
TankMR
My car takes Dextron VI
Old Aug 7, 2010 | 07:41 PM
SC400-PHAE's Avatar
SC400-PHAE
same here i have a case of it.... a local guy here sells a case for $40
Old Aug 7, 2010 | 07:43 PM
attzor's Avatar
attzor
Not 100% sure what you're getting at, but there are plenty of choices at autozone, they're right next to the oil on that big shelf in the back.
Old Aug 7, 2010 | 07:46 PM
Cyclenby's Avatar
Cyclenby
Basically, being that the information in the manual is outdated "what" should I use for power steering, fan fluid, and finally my AT transmission? Btw, vehicle has 180K miles and as stated above is a 1992 SC400.
Thanks!
Old Aug 7, 2010 | 07:53 PM
SC_coupe's Avatar
SC_coupe
Use ONLY Toyota Type T-IV ATF fluid in SC400's and NOTHING ELSE.
This article is essential reading for any SC400 owner: http://planetsoarer.com/autotrans/autotrans.htm
Old Aug 7, 2010 | 07:54 PM
attzor's Avatar
attzor
Thanks!
Just go in to autozone again, ask one of the clerks to show you all of the choices and read the back of them and find the one that suits the application, I found the fluid I needed at autozone so I know they have it.
Old Aug 7, 2010 | 08:01 PM
Cyclenby's Avatar
Cyclenby
Originally Posted by SC_coupe
Use ONLY Toyota Type T-IV ATF fluid in SC400's and nothing else.
Okay, went to the link will use Type T-IV and will order from Amazon for my automatic transmission - but again, what about power steering and fan fluids that call for DEXTRON II per the cap and owner's manual?
Btw, I asked the gal at the counter at AutoZone and she is the one that talked me into buying the Valvoline DEX/MERC (actually she recommended the AutoZone brand of the same...) /SIZE]
Old Aug 7, 2010 | 08:09 PM
twizted's Avatar
twizted
Hes is talking about for the fan not the transmission....
Old Aug 7, 2010 | 08:43 PM
SquareOne's Avatar
SquareOne
Dexron II has been superseded by the common name "dex/merc"
Old Aug 7, 2010 | 09:22 PM
SC_coupe's Avatar
SC_coupe
... and finally my AT transmission?
I was referring to that part.
Old Aug 7, 2010 | 09:26 PM
turbodremz's Avatar
turbodremz
with ATF fluids ratings, you can go up, but not down. So by using a Dexron 3/4, your only putting a better fluid in, nothing else. Same with the ATF+3 or +4. Going up in the "number rating" will not harm anything. I have been putting Dexron 3 in my PS/Trans since I got my SC and it works great.
Cyclenby's Avatar
Cyclenby
Okay, so if I have this straight I use the DEX/MERC in the fan and power steering fluids and the Toyota Type T-IV in the actual transmission - thanks!
wsrivers
Apr 6, 2017 02:24 PM
Rigon28
May 21, 2014 08:02 AM
sjc2467
Apr 6, 2013 03:58 PM
relax221
Jul 21, 2011 08:55 PM
jubay
Mar 1, 2010 01:07 AM
