brake b;eeding problem plze help sc300
Old Jul 31, 2010 | 11:40 AM
itsmeb2010's Avatar
itsmeb2010
Default brake b;eeding problem plze help sc300
i have a 1993 lexus sc300 i removed the abs pump and when i replaced it and tried to bleed the brakes i got nothing i was told you had to use a scanner to prime the abs pump im trying to sell the car as is but a guy came to look at it and told me there is a way to jump 12v power to it and prime it with out the scanner if anyone kmows how to do this it would help cause then i could fix it and people can test drive it and it will be easyer to sell thank you for youre help.
Old Jul 31, 2010 | 02:34 PM
good2go's Avatar
good2go
What if you just drove to some remote, out-of-the-way place and slammed on the brakes to trigger the ABS a few times. Then re-bleed the brakes as normal.
mtm864
Jul 18, 2010 05:39 PM
98SBF
Suspension and Brakes
Nov 13, 2008 09:28 PM
99navette
Dec 1, 2006 04:59 PM
Lexs400
Maintenance
May 30, 2004 12:48 PM
