looking into a DIY rear window replacment
Old Jul 31, 2010 | 02:11 PM
sostahoe's Avatar
sostahoe
Default looking into a DIY rear window replacment
Any help or experiences that would help in pricing and how much time and trouble it would be????
1992 Sc400
Thanks in advance.
Scott.
Old Jul 31, 2010 | 02:40 PM
shajbot's Avatar
shajbot
In the manual it says using piano wires to cut through the glue. I didn't have any piano wires laying around so I went for a pack of guitar strings. It actually cut through the glue/weather stripping pretty good. Make sure you have patience, take time at it because the string heats up fast and it would break. Also you need two people to do this method. I started at the bottom and worked my way up, the corners and the side got real tricky and finally I was really tired and went through five guitar strings, I tried a utility knife at it til finish.
Picked up a window at a local junkyard, had to strip off the old glue off, then clean it it all out. Used glue and weather stripping at Autozone, rewired the defrost and everything. $45 for the window and $30 for glue and weather stripping.
Old Jul 31, 2010 | 02:47 PM
SChema's Avatar
SChema
If you don't have any access to piano wire of guitar string, I think the braided fishing line would work just as well. You can pick that stuff up at any major store, Wal-Mart and such.
Old Jul 31, 2010 | 02:53 PM
sostahoe's Avatar
sostahoe
Default What Kind of $ for the used glass ?
How much should I pay for a used rear glass?
Old Jul 31, 2010 | 03:17 PM
megamax's Avatar
megamax
depends if the junkyard knows what they have on thier hands?? usually a place like pick and pull and u-pull it have general prices(guessing like 80 or less).
Old Jul 31, 2010 | 03:19 PM
shajbot's Avatar
shajbot
I "pulled" mine for $45 but I was offered online ones from $100 to $200.
Caseoane
May 13, 2015 09:58 PM
anu7898
Feb 18, 2013 07:04 PM
gridlock13
Mar 28, 2012 07:34 AM
flexthatdx
Jan 12, 2011 10:27 AM
GoldieLex
Jun 17, 2005 01:03 PM
