Ls400 vs tt brakes
Old Aug 19, 2010 | 05:53 AM
OneJay's Avatar
OneJay
Originally Posted by j three
One of our vendors MVP motorsports is running a special on ebc redstuff and yellowstuff. https://www.clublexus.com/forums/clu...torsports.html
I don't think they make the yellowstuff for the LS calipers. Just red and green.
Old Aug 20, 2010 | 06:46 AM
Jeembo's Avatar
Jeembo
Originally Posted by 3Rotor
Stock wheels do not fit unless you add some spacers. Many who do the LS or TT upgrade switch over to TT wheels, which looks decent on the SC.
Any clue how big the spacers would need to be? These wheels just BARELY clear my stock brakes (to the point the static weights for balancing were hitting the caliper). My wheels are really sunk though, so spacers would be fine with me.
Old Aug 20, 2010 | 09:33 AM
SChema's Avatar
SChema
I made a rough measurement and came out with 67mm from the face of the rotor to the back of the spokes. Again, it was a rough measurement, there was barely any wear on the rotor, so it should be near spec.
If I have some free time, I'll try to mount a factory wheel on a see what it looks like tonight. I have the 98 five spoke wheels. I'll get back to you with the results and try to snap some pictures as well.
Old Aug 20, 2010 | 04:29 PM
SChema's Avatar
SChema
Jeembo, I mounted one of my factory wheels on and it looks like a set of 20mm spacers should do the trick. Remember, these are the 98 five spoke wheels, I'm not sure which ones you have. Sorry I couldn't shoot any pictures.
As for wheel weights you may have them try to static balance them on a different area; maybe a couple of inches closer towards the rear lip if possible, that should give some extra clearance. Worst case, you may have to have the wheels dynamically balanced.
Hopefully this helps, good luck.
Old Aug 21, 2010 | 06:59 AM
Jeembo's Avatar
Jeembo
MUCH appreciated man!!! You definitely didn't need to go to all the trouble, but you're the **** for doing so
Old Aug 21, 2010 | 10:55 AM
SChema's Avatar
SChema
No problem, I always try to lend a helping hand.
GamblerZ
May 23, 2012 02:03 PM
shivan0124
Feb 28, 2012 10:53 PM
Dx3
Feb 28, 2008 06:17 PM
El Captain
GS - 1st Gen (1993-1997)
21
May 3, 2007 03:54 PM
GarrettSC
Dec 7, 2006 10:03 PM
