Temperature control panel dead
Old Jul 19, 2010 | 10:38 AM
gigaimage's Avatar
gigaimage
Default Temperature control panel dead
My car : 1995 Lexus SC 400 Auto.
I noticed that temperature LED is blank all of a sudden (only yellow LED background). Nothing shows up. Pushing Auto *** doesn't do nothing. None of the control (AC, Auto temperature, Airflow control, air direction fan controls) work. Power charging outlet is also not doing anything.
Only thing I can think of that would have caused these was on an uphill highway I put it on overdrive and RPM shooted more than 4 at the speed of around 70 mph. Did it blow off the fuse?
CD and Audio panel works fine (6 CD changer in trunk).
From your experience/expertise, I would like to know what went wrong and approximate cost. So they don't surprise me when I go to get it fixed.
Thanks,
ND
Old Jul 19, 2010 | 01:06 PM
jadu's Avatar
jadu
live.love.laugh.lexus
It's usually easier to swap it out. Someone in the classifieds should be selling one
Old Jul 19, 2010 | 01:09 PM
romycha1's Avatar
romycha1
Have you tried troubleshooting at all... at least checking the fuses yourself before getting it diagnosed?
Old Jul 19, 2010 | 01:47 PM
gigaimage's Avatar
gigaimage
Thank you all for your responses. Romycha1, yes, one of the CIG (15A) is busted. First it was hard to locate the fuse panel on driver side kick panel. But finally found it. I used tail light 15A to test, and it worked.
I think I know what to do next.
Again, Thanks.
ND.
Old Jul 19, 2010 | 01:48 PM
turbopwr's Avatar
turbopwr
Check your lighter socket to see if theres any coins that fell in causing the fuse to blow out. Seems like a common problem on here. The cig lighter and climate control are on the same circuit.
Old Jul 19, 2010 | 01:54 PM
gigaimage's Avatar
gigaimage
Yes, there was a metal thing fell in the socket. Thanks.
Old Jul 21, 2010 | 03:02 PM
nrthwzrd's Avatar
nrthwzrd
Thanks for the help, same thing just happened to me and I had no clue the CC was on teh same circuit as the lighter plug - just a blown fuse.
Glad I checked through here first!
NortH
Old Aug 27, 2010 | 02:59 AM
Confusion's Avatar
Confusion
Okay this just happened to me tonight, I just bought a cell phone charger for my sc, plugged it in it went on and the whole a/c unit went off along with the cig lighter. Can anybody please walk me through this, and which fuse to replace, I hope it was just the fuse and nothing serious.
Brittney
Sep 2, 2018 01:39 PM
petersc400
Dec 5, 2011 07:44 AM
mmmmichael
Sep 12, 2011 09:44 PM
P Weezy
21
Sep 22, 2008 03:01 PM
lexusnexus
IS - 1st Gen (2001-2005)
Nov 11, 2002 04:23 PM
