Bought SC300 (T67 GTE)
that's why i don't buy people projects, hope you get it rite!
where do you live in missouri?
no good, pull the head off and check it out. you can get the head machine and replace the head gasket. if the bottom end looks ok. you could a little oil down the spark plug and see if compression comes up also. i have seen cars overheated like crazy but they still ran after.
umm get the head offffffffff man well its a good start once you done u will have a nice ride sir glk.
charge the battery and do it again. Also this happened to me with a motor a while ago.
it would have to be pretty screwed for it to have zero compression. does it crank at all?
if it was running fine before its not going to give out all of a sudden to 0 compression if you really shut it off in time. I would redo the test with a good battery and use some oil this time.
they mean take one of your spark plugs out, put a cap full of oil down into the cylinder, and then test the compression. This will let you know if your rings are bad.
blowing, compression, difficulty, efi, fuse, lexus, noise, overheated, problem, sc300, sc400, sitting, smell, starting, test
