SC- 1st Gen (1992-2000)
How to connect reverse light i did 5 speed Swap HELP
Old 05-17-10, 06:04 PM
ArtZ
ArtZ's Avatar
Default How to connect reverse light i did 5 speed Swap HELP
How can i make my Reverse light work, i did the 5 speed swap but i have no idea on how to make the light work
help pliz
Old 05-17-10, 07:15 PM
Gspec
Gspec's Avatar
Use an ohm meter to check for continuity between the reverse light plug in at the taillights, and the unused plugs from the old auto trans harness under the car.....once you've identified what wire it is, prob the same trans harness until you find one with constant power with the key on....hook up those two wires to the reverse light switch on the 5-spd (doesn't matter what color to what color, will work either way) Done.
kaahari
Performance & Maintenance
03-29-16 05:36 AM
djkevin510
07-14-12 03:24 PM
SCott300
09-06-11 04:23 PM
Imsc300
09-29-09 06:54 PM
k311in
06-08-09 12:44 PM
Quick Reply: How to connect reverse light i did 5 speed Swap HELP
