Turbo Compressor Chipping?
Old May 17, 2010 | 01:23 PM
lemmiewink's Avatar
lemmiewink
Default Turbo Compressor Chipping?
Hello,
I have a Bullseye s366 and I took off the intake today to get to something and found this.
I apologize for the blurry picture, but it seems as if the white part is flaking off and it is taking the surface of the wheel with it.
Should I be concerned and talking to bullseye right now?
Here is what the wheel looked like before it was put in the car
As you can see, there is a white marker there. I just assumed that it was part of the balancing process. Any help would be great.
Thanks!
Old May 17, 2010 | 05:43 PM
lemmiewink's Avatar
lemmiewink
I apologize for the quality. Camera is kinda dumb. Here are a couple more pics which are, hopefully, more helpful.
I'm specifically talking about the white marked area. It is as if "paint" was chipping off the wheel to the bare metal. It is not discoloration since I can feel a definite unevenness between where the "paint" chipped and the rest of the wheel.
I'm specifically worried about some things.
1) will it affect the ability of this turbo to flow air.
2) will it affect its balance and wobble at high psi (wastegate pressure atm ~10 psi)
3) How much will it cost to repair it if needed? Should I get a new unit? New platform?
My camera sucks so, this is probably as good as it gets in quality.
Thanks!
Old May 18, 2010 | 04:28 PM
lemmiewink's Avatar
lemmiewink
Disregard. Contacted manufacturer and they say its normal, caused by air speed goin over the wheel.
Old May 18, 2010 | 08:42 PM
turbodremz's Avatar
turbodremz
that doesnt look normal...are the compressor blades coated with something?
Old May 19, 2010 | 01:04 AM
MIGS's Avatar
MIGS
is that a twin scroll, 60 trim? sweet BW.
1) if its just cosmetic, probably not..
2) no, shaftplay would affect that..
3) if you havent installed/run it already, see if they'll swap it out for another one. if not, dosen't look like it'll be a problem anyways (as long as there's no corrosion either).
Old May 19, 2010 | 09:39 AM
madmax98's Avatar
madmax98
Did you post on the SF? By the way, this is normal, it's just manufacturer's balancing mark........ Mine was gone the first time i hit 15 psi hahahah
Old May 19, 2010 | 04:08 PM
lemmiewink's Avatar
lemmiewink
Yes I did. I talked to Bullseye and that is what they said as well.
JayC708
Automotive Care & Detailing
Apr 25, 2017 10:19 PM
MyIS350G
Apr 14, 2016 04:45 PM
Carnevino
RC F (2015-present)
Feb 20, 2015 05:05 PM
sniper
Jul 7, 2005 11:16 AM
