Uneven Tire Ware!
Old May 12, 2010 | 09:23 AM
need2boost's Avatar
need2boost
Default Uneven Tire Ware!
After putting on my supra kyb shock and tein springs, I got some brand new tires put on the sc300. This was about 2 months ago. Tire specs (245/3518, and 265/35/18 on 9.5 and 10 wheels) Dunlop Sport Max and Sp9000
I got an allignment done right away to factory specs. After the car was done with the allignment, I asked the guy if everything was alright and if the camber was really messed up. He said no, just toe was really out of specs. Im thinking to myself, thats good that toe is fixed and camber is straight. Well fast forward to last week. I notice some extreme tire ware (5k miles later). I brought it back to the allignment shop to see if everything was in spec.
Toe was to factory specs, but the guy never bothered with the camber as the camber bolt was rusted and he couldnt get it to move (now he tells me).
Camber up front is -1.75, and rear is -2.75, toe being .44 totalled which is closed to factory specs I believe. If toe was to factory specs, why such tire ware? I thought toe was the main reason for uneven tire wear? Should I try to Zeroed out the toe? Or is that too much negative camber? Rear tires are shot. Half of the inside of my rear tires are gone. The front however wear only on the inside edge.
The car drives striaght and doesnt pull or anything.....
Old May 12, 2010 | 04:39 PM
good2go's Avatar
good2go
sounds like negative camber effects to me.
Old May 12, 2010 | 05:49 PM
GSteg's Avatar
GSteg
The SC runs quite a bit of toe in for the rear end. What is the toe in the front? Normally camber isn't an issue until you've hit -2.50 degree and seems like you're over that. You cannot use factory spec because your suspension behaves different dynamically even if your static specs are the same as stock. Different geometry requires different numbers.
"In-spec" means nothing. I can tell you that almost every machine out there has different ranges for what's acceptable. What shows up as red on one machine can be green on the other.
I would take it to another shop for an alignment. Seems like they half-assed the job simply because they were lazy, yet you had to pay full price.
Old May 12, 2010 | 06:22 PM
need2boost's Avatar
need2boost
what are some good allignment specs? i searched and saw this link......
http://www.mkiv.com/techarticles/lan...ent/index.html
Old May 12, 2010 | 09:00 PM
GSteg's Avatar
GSteg
That's written by our very own Lobuxracer. You should PM him, but I don't know how much knowledge he has on the SC300. But being that both cars are very related, maybe he can shed some light for you.
Old May 13, 2010 | 11:06 PM
need2boost's Avatar
need2boost
nobody else has allignment specs they wont to put up....anybody that has similar setup would be great!
Old May 21, 2010 | 12:36 AM
xx69xx's Avatar
xx69xx
Look up the lance alignment specs. But you have a camber issue. If it was toe then your would see feather like wear or scalloping look to it. Camber just wears the inner or outer section of the tire depending if its neg or pos
Old May 24, 2010 | 08:43 AM
need2boost's Avatar
need2boost
thats the link i posted....i just want to see other peoples allignment specs right now with similar setup with less tire ware...e
Old May 27, 2010 | 02:19 PM
xx69xx's Avatar
xx69xx
-1.00 of camber and 0.00 toe is not a heavy wear by anymeans. Go with the lance set up or if not then go with OEM specs if you dont want the performance part.
Old May 28, 2010 | 08:22 AM
gtsfire's Avatar
gtsfire
I was going make a new thread until I saw this one.
I have a 98 SC300 with MKIV TT wheels and stock SC springs/tokico blues. The rear tires are beginning to feather on the insides and it's becoming quite annoying because of the sound they make. I noticed the fronts are barely starting to feather.
I had it aligned right after I had the new tires put on. Since they are bigger wheels should they have aligned to the specs for a MKIV supra or does it matter? The car drives straight but it now makes that "wuh wuh wuh wuh wuh" sound going down the road.
Old May 29, 2010 | 03:17 PM
need2boost's Avatar
need2boost
im gonna get some new control arm bushings and camber bolts....will zero out the toe and -1.50 camber....
NealM
Suspension
29
Mar 7, 2012 11:32 PM
SC4ALBERT
Feb 3, 2012 10:35 AM
ray123
VIP Style
Aug 5, 2011 12:33 PM
hatteroo
Jan 17, 2011 09:44 AM
dave197878
Apr 3, 2009 07:15 PM
