grrrr...1jz tach issue...
Old Jun 27, 2011 | 08:45 PM
DoomLight's Avatar
DoomLight
i did the tach fix. but my tach needle is very low on the gauge. like about 200 rpms and i know its idling higher than that. maybe i need a better wire to be soldered back on the cluster... i have a 92 with the r109 resistor by the way.
anyone else have a lazy tach readout after this modification?
Old Jun 27, 2011 | 08:53 PM
6SOARER's Avatar
6SOARER
I used a paperclip, it works fine so far
Old Jun 28, 2011 | 05:32 AM
DoomLight's Avatar
DoomLight
i think i'll have it redone. i still need like 2 or 3 needles anyway. can't see my MPH and the gas gauge flickers
Old Aug 14, 2012 | 07:29 PM
queenskid9's Avatar
queenskid9
did redoing fix your issue? i have the same issue rite now and i used solder instead of a wire, maybe ill redo it with a wire,
Please let me know what fixed your issue
Thanks
Old Aug 14, 2012 | 07:50 PM
megamax's Avatar
megamax
Originally Posted by Sag
So...here I go
Have 94 SC300 with 1jz swap
same problem tach does not work,
I saw the video, but I dont have r109 in that place, I have it elsewhere,
Also did not find R2 resistor.
Any ideas?
^^iam with this guy.
Old Aug 15, 2012 | 05:59 AM
DoomLight's Avatar
DoomLight
Thanks
whoa! blast from the past! i had to get another cluster. my speedo was dead.
Old Aug 15, 2012 | 11:13 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Any more results on this cluster issue? I used R109 for mine and it works great. For the speedo, I used the MC from DM on the side of the R154, and for the temp, I had to gorund both sides of wire in the passenger kick panel. Only problem I have now, is the blue LED needle from Lextech on the MPH is crapped out on me.
ducatisamy
Oct 3, 2016 09:48 AM
Tommy150
Jun 6, 2014 05:43 PM
Slow_Sc3
Oct 4, 2009 03:52 PM
sc250tt
Mar 31, 2007 07:51 PM
