sc300 dead? need help
Old May 2, 2010 | 07:05 PM
wilkey09's Avatar
wilkey09
Default sc300 dead? need help
so today went to my car and went to start it and it just cranks has fuel, spark, everything is good looked at timing nothing wrong ohm the distributor, does anyone have any ideas? been told by my supra buddies sounds like ecu took a poop has anyone had this happen i need my car?
Old May 2, 2010 | 07:29 PM
HellFish's Avatar
HellFish
somethings missing. you cant have fuel and spark and not start. have you done anything to the car?
Old May 2, 2010 | 07:42 PM
wilkey09's Avatar
wilkey09
no its completely stock I have fuel, spark , compression this is why i am stumped everything turns what if the battery is low would that be something
Old May 2, 2010 | 07:43 PM
HellFish's Avatar
HellFish
possibly, but if youre able to crank it, it should fire. how does everything in the dist. cap/rotor/wires look? possible crank sensor issue even?
Old May 2, 2010 | 07:48 PM
FrankT's Avatar
FrankT
Does the CEL come on when you turn the key to ON?
This verifies the EFI circuit and the ECU are powered up and ready.
Old May 2, 2010 | 07:52 PM
wilkey09's Avatar
wilkey09
CeL comes on but no codes! i checked it
and the pickup inside the dist has a crack in it but it ohms out good
speedf50
Oct 2, 2022 08:26 PM
supersc30
Feb 19, 2017 07:46 AM
NSeagle78
Maintenance
May 5, 2011 07:42 AM
eagles22mh
May 11, 2010 08:55 AM
ksort86
Mar 7, 2009 09:09 PM
