Tilt steering repair
Old Jan 14, 2012 | 07:12 PM
  #271
redsc40093's Avatar
redsc40093
thanks guys i had the same problem but not any more thanks to my club lexus family working prefect now.
Old Feb 2, 2012 | 07:29 AM
  #272
DallasSC's Avatar
DallasSC
I have a similar problem with my tilt motor. It makes a quick grind but doesn't tilt. I took out the 3 screws on the column but how do you take the column apart? I don't want to break it so I figured it's best to leave it until I find out how.
Old Feb 4, 2012 | 08:35 PM
  #273
RiCeRyDa's Avatar
RiCeRyDa
i saw this guide like 3 years ago and finally used it today i went with the garden hose washer and white lithium grease. love this forum!
Old Feb 5, 2012 | 02:31 PM
  #274
ureclipsed's Avatar
ureclipsed
10th Gear
Default Tilt Steering would NOT go down
OMG!!! Thank you soooo much for this post. It was very easy to fix, and I had a spare washer in my tool box!!! I had just bought this car, and the dealer would not fix it, because they were told it would cost $600 to fix !!! It is very easy to do!
Old Feb 25, 2012 | 12:47 PM
  #275
Microsoft's Avatar
Microsoft
Thumbs up
WHOOO!! It worked for me! I used the washer inside an unused garden hose nozzle. Its made of rubber so i dont know how long it will last. The metal washers I had laying around were not big enough. the hose nozzle is a perfect size. I'll just bring one to home depot to match up the size. THANKS FOR SHARING THIS FIX!
Old Feb 25, 2012 | 10:03 PM
  #276
fc3s's Avatar
fc3s
My steering wheel tilts but doesnt telescope (in and out)
Anyone had experience with it?
thanks
Old Feb 25, 2012 | 11:54 PM
  #277
rcchris7's Avatar
rcchris7
It is 2:52 am... I'm going to tackle this right now haha I have a brand new hose rubber on the top of my tool box from the summer
Old Mar 2, 2012 | 11:44 PM
  #278
818sc400's Avatar
818sc400
ive searched this whole thread, where is the video??? can someone pls post a vid
Old Mar 4, 2012 | 08:54 AM
  #279
Pezlo's Avatar
Pezlo
I did this take, took me some time to get the nut and the blue wheel off... but omg im so happy. I made a washer out of the spare plastic piece that usually comes in a tool set. lol oh well did the trick
Old Apr 3, 2012 | 02:42 PM
  #280
95sc300na's Avatar
95sc300na
I did this today super easy It only took me about 15min and that's only because I used a metal washer and had to make the hole bigger with a drill bit and drill!!! Very happy with the outcome
Old Apr 3, 2012 | 09:49 PM
  #281
sootycat's Avatar
sootycat
My attempt was not successful... wasn't able to remove the screw from underneath the steering column. Maybe it's stripped? It felt like the screwdriver wasn't even grabbing the head, but the head did not look stripped.
I'm going to see if my mechanic can get the screw out... then I will finish the job myself. They swore I'd have to replace the motor... Lol.. I guess they don't read this forum
Old Apr 4, 2012 | 06:12 AM
  #282
SpadedOne's Avatar
SpadedOne
I just did this the other day. Works great! I got 3 rubber washers, put 2 on the back side and one on the front. Works like a charm! Thanks for the info!!!!!
Old Apr 15, 2012 | 04:23 PM
  #283
stratman3's Avatar
stratman3
Default SC400 Telescoping Steering Wheel
thanks
Did you find a fix to this? Same problem here, up and down is fine, in and out is not working
Old Apr 17, 2012 | 09:43 AM
  #284
ill eagle's Avatar
ill eagle
excellent post!!! im having the same issue right now and it sucks cause my steering wheel is stuck tilted all the way up. i am about to try and fix mines now. hope it works
Old Apr 17, 2012 | 01:08 PM
  #285
Tommy2JZ's Avatar
Tommy2JZ
I need to do this to my car -__-
