Guys rear bumper removal help!
Old Apr 9, 2010 | 09:51 AM
Dr.Fate's Avatar
Dr.Fate
Default Guys rear bumper removal help!
Is there a pdf on how to take off the rear bumper? I need to get mine off asap!!!
Thanks
Old Apr 9, 2010 | 10:58 AM
attzor's Avatar
attzor
All you have to do is unbolt it and remove the black plastic screws, it's really not hard at all, just take out the head lights, remove the some of the trunk liner and unbolt it with a 10mm wrench...
Old Apr 9, 2010 | 11:22 AM
sc400vip's Avatar
sc400vip
yeah youll have to also unbolt the rear factory rocket panels they have 3 little bolts on each side sometimes this get rusty they tend to just brake when your unbolting them, you have to unbolt them from under you car, underneath your rear lights theres 3 more plastic bolts on each side, and the rest you could get from inside the trunk. carfully remove the wiring from you rear lights so you dont burn the bulbs this things are sensitive unless you dont mind and just go buy some more their cheap like 2.99 for two hahaha is pretty simple just follow the seams aroud your bumper and look for bolts to unbolt....
Old Apr 9, 2010 | 12:16 PM
scviolence's Avatar
scviolence
this is so true i keep a new pack in my center console cause mines keep popping!! lol ill find the short one of these days.
Old Apr 9, 2010 | 01:08 PM
czar07's Avatar
czar07
should be pretty easy after reading these.
Old Apr 9, 2010 | 03:09 PM
t70 supra's Avatar
t70 supra
does anyone have the front
Old Apr 9, 2010 | 03:16 PM
Matador's Avatar
Matador
Just take out the headlights and start unbolting stuff. If you still have the plastic shield on the bottom it may take you a tad longer due to all the clips.
Old Apr 10, 2010 | 12:35 AM
jintei's Avatar
jintei
unlike my 7th gen celica, the sc's bumpers are a pain to take off. way too many bolts and clips, lol.
Old Apr 10, 2010 | 03:59 AM
SpuGen's Avatar
SpuGen
The bolts on the rear bumper side bottom are 2 full *****es.
I ended up just reefing on it until it came off. It was damaged and getting replaced anyways.. so I didn't care.
Save the bolt bars (whatever the hell it's called) that are on your rear bumper. it's on the part that bolts up to your rear quarters. Save this. You'll need these pieces when you go and install your bodykit if you have one.
It's a black plate piece that has a slight curve. 3 bolts on it. Just tap the bolt sdie with the hammer to get it out.
Old Apr 10, 2010 | 10:38 AM
sc400vip's Avatar
sc400vip
wow that front bumper is a pain man just start unbolting i started mine at 6:00pm and finished with a new bumper on at 10:00pm just because of all the bolts in that front man theres bolts on top,under,and on bothe sides, plus you have to take those headlights off too, man is a pain....man get ready to work and bring luch for lunch hour....hahaha
Old Apr 10, 2010 | 01:20 PM
Matador's Avatar
Matador
Just remember to leave off a few so that next time goes quicker
Old Apr 10, 2010 | 03:06 PM
attzor's Avatar
attzor
I've never removed a bumper before and it took me 15 minutes.......
chashiubow
Dec 21, 2024 08:47 AM
Schimmy
Feb 11, 2019 06:57 PM
Kybball#1
Oct 26, 2014 03:58 PM
jays400
Jun 7, 2005 02:24 PM
Slow_go_400
Oct 8, 2002 08:58 AM
