Does this look like a sticking caliper or something else?
Old Apr 8, 2010 | 01:57 PM
Sup2jzgte's Avatar
Sup2jzgte
Default Does this look like a sticking caliper or something else?
So what are your thoughts on my brake rotors? I'm thinking that the calipers are dragging, but I could be mistaken. What are your thoughts?
Rear Drivers side Rotor
Rear Passengers side rotor
Front rotor......this one looks good, nothing like the rears
Old Apr 8, 2010 | 04:00 PM
spdrcr771's Avatar
spdrcr771
drive it for alittle while then slow down easy, get out if you smell brakes burning in the rear then thats most likely your problem, could be stuck piston's, or stuck caliper on the floater pins.
Old Apr 8, 2010 | 05:02 PM
SC300_704's Avatar
SC300_704
mines used to have a stuck caliper. whenever i drive to anywhere my rear driverside rotor will always turn purple/yellowish b/c it will get so hot. also smells like something is burning to. i replaced the caliper and it went away
Old Apr 8, 2010 | 05:18 PM
Sup2jzgte's Avatar
Sup2jzgte
I just dont understand why there is so much rust on the braking surface of the rears and not the fronts.
I'm debating on whether or not to rebuild the calipers.
Old Apr 8, 2010 | 09:33 PM
gldndrgn14's Avatar
gldndrgn14
are you sure its the right size pads?
Old Apr 8, 2010 | 09:37 PM
Sup2jzgte's Avatar
Sup2jzgte
I have no idea...........this is the way the car came when I bought it. I just ordered new rotors and pads, but I'm not sure if the caliper is the issue.
jacobdjenn
Mar 11, 2017 08:26 PM
Road Rage
Feb 29, 2012 08:49 PM
kkee
RX - 1st Gen (1999-2003)
Aug 8, 2010 09:09 PM
pinoybboy
May 2, 2006 03:51 AM
